Page 25 of 78 FirstFirst ... 15161718192021222324252627282930313233343575 ... LastLast
Results 241 to 250 of 778
Thread: Complete bolt in Screen/CPU/HD/PS - indash
  1. #241
    Constant Bitrate diosagain's Avatar
    Feb 2007
    New Jersey
    I definitely am need of a custom case pretty bad right now. I just have a huge mess on my table. Joe, take a look at my build thus far. Anyway, let me know where to paypal the money to (I know you have posted this in your threads, but I don't want to send until you tell me to).
    First Time Fab - 2003 Ford Explorer - Please help! - A lot of pictures...
  2. #242
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    diosagain,
    just checked out your thread, looks like your parts need a good grounded chassis to call home! as long as you double checked that the finish size will fit your application paypal is joe.shock@gmail.com $65 shipped. Be sure to include your address.
    Sorry I have not been on the boards much this weekend, had a little but of mustang trouble on some black ice. All is ok but i need to get a couple scrapes and dents bumped out from the fender flares. Going in the body shop wed to have the repairs done. My poor baby got banged up
    Anyway Im fast approaching a HQCT module purchase which will be the next major step on this project so stay tuned for some AM/FM RDS hardware/software
  3. #243
    Feb 2007
    New Jersey
    Joe,
    First off sorry to hear about the Mustang. I am sure they will fix her up as good as new. How do you think the best way to measure is? Should I pull out the factory radio and just take mesurements of every angle? Let me know what you think I should do. I am interested to know how the HQCT module turns out. Can you hack it to work with your exisiting car antenna? Also, you mentioned something about building a volume knob. When you do get around to it, it would be great if you detail how you go about that process as well. Thanks! I am going to send the money now.
    -Ross
  4. #244
    Jul 2005
    Motorcity
    Blog Entries
    1
    Yup, measure the the OEM radio chassis. Height, Width, Depth, in inches. I will bend the chassis to match these dimensions unless you look into the dash opening and discover there is more room for a larger chassis. You can also use the autocad sketches posted earlier in the thread to determine if any modifications to my standard chassis are even necessary.
    The volume knob i made buy gutting a USB scroll mouse. I basically did a little fab work to disconnect the buttons and only use the wheel sensor. I used a piece of 1/8" round aluminum stock to transfer the turning motion of the knob back to the PCB sensor. Works golden. For software I use a program called 'volumouse' Im going to try to dig up some pics of this while i was building it.
    The HQCT module will be connected to my OEM antenna jack.
    One more thing Ross, The paypal payment from 'xxx.' Is from you correct? It does not have your name on the receipt anywhere and just wanted to double check
  5. #245
    Feb 2007
    New Jersey
    Yes, that's my company. Joe if at all possilbe can you just edit your last post to remove the company name. Thanks. With google indexing everything these days I just would rather my business name not be associated with my posts. Thanks!
    -Ross
  6. #246
    Jul 2005
    Motorcity
    Blog Entries
    1
    Name Removed. I forget about google sometimes and you're right, it will always bring up mp3car in searches
    Any word on when you will have the dimensions?
  7. #247
    Feb 2007
    New Jersey
    Tonight I was working on the screen fabrication. What a pain; but you will definitely have them by the end of the day tomorrow. I think its the same as the Mustang Double din, but I might as well measure to be safe. See the thing is I am going to fab the LCD into the trim and try to sit the indash case your building using a grinded down fabricated metra kit right behind it. I hope it works; I would really like to get everything in the dash. BTW thanks for removing the name. These days we are all just one google search away from losing our privacy.
    Also, I got a version of your chopped down Win XP, and everything was great except when I tried to get on the internet. I tried just about everything. I even ran my cable modem via usb, installed the drivers , and took a direct route bypassing my router; but still no luck. Just wondering your thoughts on it. I guess worse case I can download TinyXP or just nlite my own version of windows, but figured I would ask first.
  8. #248
    Jul 2005
    Motorcity
    Blog Entries
    1
    I would probably give nlite a try Ross, its easy to use and then you have an OS configured exactly for your system. My version has every driver stripped out and my own integrated in. If your not running the m10000 you will need your chipset drivers installed before you get on the net.
    Im glad to hear the fabbing is going well! If you need any other brackets made for mounting the chassis let me know, i can bend you some 1" angles or something so you have some mounting tabs for the dash.
  9. #249
    Feb 2007
    New Jersey
    Sorry Joe, had a rough day but I definitly will have pictures and measurements tomorrow. Also, if at all possible can you snap a picture of your mouse scroll wheel you used for the volume? I am trying to make one and I think with a shot of yours I would have a better idea where to start from. Thanks again for all of your help.
  10. #250
    Feb 2007
    New Jersey
    OK, all the measurements are done. I am going to upload them to my server and I will PM you the link. I kept them rather big so you can see the exact measurements. I didn't have as much room behind the radio as I thought so we are going to have to keep the case a little shorter then I intended. I also have to mount the LCD pcb board, m2-mtx, and the HQCT somewhere in the case, I guess sitting on top of MDF wood screwed into the case, kind of like you did. I just hope everything fits with all the wiring, but I think it will. I am glad I went with the 2.5 inch HD now.
  1. indash touchscreen vga rca inputs
    By mike86ttype in forum Classified Archive
    Last Post: 01-30-2005, 10:30 PM
  2. FS: Indash Unit from tm-701L
    By BoraXP in forum Classified Archive
    Last Post: 01-15-2005, 03:48 PM
  3. Cheap indash monitor
    By darkhavoq in forum LCD/Display
    Last Post: 11-21-2004, 03:01 PM
  4. FS: Complete Mini-ITX CarPC w/Xenarc Monitor + More
    By DLe in forum Classified Archive
    Last Post: 10-19-2004, 09:15 PM
  5. Nissan Sentra 1996 GXE Complete Project. 14'' Screen
    By criterzzz in forum Show off your project
    Last Post: 08-01-2004, 01:07 AM
