Originally Posted by
MemphisMustang
You take your screen out of it's original enclosure and epoxy it to the Metra faceplate (see post #320 above). Then you screw it in to your dash and put the panel back on (see post #321). Voila, clean looking install with minimal work.
The alternative is to rig the screen up to the dash somehow then take the dash panel and bondo/fiberglass/whatever it to try and get the same look. Much more time consuming and not everyone has the equipment and skills/patience to do so. Although it does give you more choices for the end look.
