Page 37 of 78 FirstFirst ... 272829303132333435363738394041424344454647 ... LastLast
Results 361 to 370 of 778
Thread: Complete bolt in Screen/CPU/HD/PS - indash
  1. #361
    Jul 2007
    I think i would like to get a case from you. What information do you need from me specifically to manufactuer it? Also can i send you the screen to assemble and return to me? (or have the screen dropped shipped to you)
  2. #362
    Newbie epod86's Avatar
    Jan 2007
    I'd be interested in one as well. Casing is pretty much the last thing on my to do list. That and a IDE-to-CF. Still deciding if I want to do it.
    Car PC Progress:
    Planning: 90%
    Parts: 90%
    Fabrication: 10%
    Installation: 0%
    OS: 60%
    Software: 20%
  3. #363
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    The embedded OS is the best solution for the rock solid stability in the car. Media and such is fine on a physical drive but when the OS is seeking files from a platter and you hit a pothole its not pretty. Flash hardware is much more shock resistant plus an XPE build can be made very small and robust depending on what you are going to do with it. Mine is for the most part and entertainment and GPS console so the OS is quite small, things like networking, printing, drivers and many more unnecessary modules have been removed in favor of a speedy kernel and a stable system. Only the exact drivers for my hardware are present. I even went through all the folders and removed the .txt log files form the install before deployment. My total OS is under 200 mb installed.
    I have my carPC pulled from the mustang right now as I am upgrading a couple parts and removing the wooden dowels in favor of .063 aluminum shelfs and standoffs on all hardware. I may even swap my original prototype chassis out for a new production model. The prototype has A LOT of holes in the sides from different hardware configurations I took a couple pics of mine vs. gregs to show what a couple years of progress yields. Mine is the chassis with only the motherboard mounted and gregs is the one with the LCD controller, TS controller mounted. Im also considering a laptop drive so I can fit everything inside. Time will tell
    Hump I will PM you back shortly about your request
  4. #364
    Jul 2005
    Motorcity
    Blog Entries
    1
    Lcd Testing
    Nice photograph of the xenarc (Hitachi) LCD clarity
  5. #365
    Jan 2007
    Well, I've decided to go with RR instead of centrafuse which was my main reason for not going with the CF embedded solution. Now I have to go read up on RR and HORM. Yay.
    I figure now is as good as any time to drop this picture of my current model. It's very much based on blk02si 's model, but I just added the ford factory mounting tabs. In it is he mobo, DSATX mounted to the top, HOLUX in the middle, and the Hawking wifi tucked behind the siding (you can't see it).
    FYI: Stand-offs take up a lot of your precious height.
    Car PC Progress:
    Planning: 90%
    Parts: 90%
    Fabrication: 10%
    Installation: 0%
    OS: 60%
    Software: 20%
  6. #366
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by epod86 View Post
    CF = Compact Flash
    Its a flash memory module I run the OS on. I fun XP embedded OS from compact flash and also run RR on the flash. The frontends have nothing to do with the flash module hardware.
    I HATE centrafuse frontend (or any closed source app) and its never seen my carPC
    Very nice drawing, I like the mounting provisions. How are you going tp mount the LCD?
  7. #367
    Jan 2007
    Whoops, messed up that brain to text translation there. One of the reasons that I didn't want to go with the compact flash was that CentraFuse doesn't have good EWF support. But with further research, I don't think RR does either. Seems like installing RR to second, writable partition is a better idea and running the OS and RR only off of the protected drive and moving the RR.ini file to the writable part to get resume features. Does that make any sense? Anyway, LSX Void has grown on me. The reason I preferred Centrafuse was it handles the music library better. I went through and fixed all my mp3 ID3 tags (like 6 hours of work there) and so now RR works a whole lot better.
    Not quite sure about the screen. It's an 8" that won't go in a double din unit. I have a spare pony face plate, and so I'm going to see how to go about integrate it. I'd like to bolt the lcd and a little bit of it's housing to the casing, so that it's more 'drop in.' Either that or just do a molding job, but that would make take-down more difficult. Need to take it apart and see what the lcd boards look like. Might go under the little shelf nicely.
    Car PC Progress:
    Planning: 90%
    Parts: 90%
    Fabrication: 10%
    Installation: 0%
    OS: 60%
    Software: 20%
  8. #368
    Newbie nano's Avatar
    May 2007
    Guadalajara , Mx
    Angry i just broke my screen :@
    hi,
    i was putting together my car pc like i said before that its like your idea but
    with a mac mini and a sliding lcd but somehow i broke it
    o well , it was a NR 701 lilliput anyways i need a new one
    but i already have the mount and everything i am wondering if
    you know the dimensions of you lcd without the plastic cover
    just the screen to see if could i buy a xenarc or buy another
    lilliput i thing the new model its NR 702 and i am hopping
    that that new model has the same dimensions that the older
    17 cm W , 10.9 H cm
    centimeters because i am from mexico , sorry guys
    i have the pictures will upload tomorrow if you want to see how
    its going i am just stuck on how to make the lcd move back with
    a motor and a button , now i do it manually
    any recomendations on and great 7" screen will be apreciated
    TIA,
    nano.
  9. #369
    Jul 2005
    Motorcity
    Blog Entries
    1
    I actually have 2 extra 7" LCD (screens only) that both work and no controller for them so I can sell you one if you want.
    Epod you should try RR with my skin, its the only frontend/skin combo with native EWF support. My batch files could be adapted to other software platforms but it will give you control over an EWF drive with a button driven interface instead of the command line.
  10. #370
    Jan 2007
    Thanks blk. I did give your skin a try earlier in the week. Sorry, but the back button wasn't quite what I was looking for. I'd like one that doesn't behave like a browser back with a 'history list' and instead one that functions in the logical order of the menus. I guess I could look into coding things to work this way, but unfortunately I have bigger fish to fry. My DSATX's brain stem is behaving badly. I haven't even looked into EWF yet, and gave up on minlogon cuz my motherboard has the dreaded ACPI problems when minlogon is used. Sigh, don't you love debuging .
    PS: any chances on a case? Just ordered an addonics CF-IDE, So case is the only thing holding me back. I could hack up the old radio casing but the solder screws are a b***h.
    Car PC Progress:
    Planning: 90%
    Parts: 90%
    Fabrication: 10%
    Installation: 0%
    OS: 60%
    Software: 20%
  1. indash touchscreen vga rca inputs
    By mike86ttype in forum Classified Archive
    Last Post: 01-30-2005, 10:30 PM
  2. FS: Indash Unit from tm-701L
    By BoraXP in forum Classified Archive
    Last Post: 01-15-2005, 03:48 PM
  3. Cheap indash monitor
    By darkhavoq in forum LCD/Display
    Last Post: 11-21-2004, 03:01 PM
  4. FS: Complete Mini-ITX CarPC w/Xenarc Monitor + More
    By DLe in forum Classified Archive
    Last Post: 10-19-2004, 09:15 PM
  5. Nissan Sentra 1996 GXE Complete Project. 14'' Screen
    By criterzzz in forum Show off your project
    Last Post: 08-01-2004, 01:07 AM
