Page 52 of 78 FirstFirst ... 2424344454647484950515253545556575859606162 ... LastLast
Results 511 to 520 of 778
Thread: Complete bolt in Screen/CPU/HD/PS - indash
  1. #511
    Dec 2007
    Quote Originally Posted by blk02si View Post
    I am going to be cutting a new batch in the next couple days, should have it out right around the 1 week timeline. Nothing like a nice fresh new pile of parts to play with
    lol yea no kidding ... thanks again for the help and the qucik work Joe
    Zach
  2. #512
    Jan 2008
    Will this chassis work in a 2006 Toyota Sequoia?
  3. #513
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Measure your OEM chassis to be sure. You'll want to take a peek in the dash if you're going to do a bolt it.
  4. #514
    Jul 2005
    Motorcity
    Blog Entries
    1
    External LCD buttons added
    In the spirit of hardware I decided to tackle a small Sunday project.
    My LCD controller is inside the chassis which is behind my dash, which are where the 5 buttons to control power, sync, brightness, etc are located. I have never really used them since the monitor auto-powers on so they lie unused for some time.
    With the temp here in MI at about 5 degrees F, yes 27 degrees below freezing, I realized that the monitor had "forgotten" it horizontal sync and was displaying halfway off the screen. I'm going to attribute this to the extreme cold as this is the first time i've ever seen the xenarc do that. Anyway its usually just hit a couple buttons to Auto-Adjust the display and you're back in business. That is, if those buttons are not buried
    So, since I pulled out the PC today to hit those couple buttons I decided to add an interface so I can access those buttons with the carPC completely installed as it usually is. I pondered for awhile and came up with quite a few different ideas. I decided I wanted to do it cheap, like $10 cheap so I thought about it some more. One more requirement important to me was visually pleasing. I ended up buying a male/female rs232 plug and small PCB from radio shack, total cost $8.26. I had 22 guage wire in the computer toolbox. Here is what transpired after a few hours. Now I can just plug in the small board I made and have my LCD buttons, once finished adjusting I just unplug the "button key" and am just left with a techie looking serial port on my dash
    I only needed to run six wires for the 5 buttons, they were all ground referenced so it made it quite easy. Final product works flawless and snaps/unsnaps into place.
    So that is the story of my $10 sunday mod.
    (Oh yeah had time to add about 10 gigs of new media while the new parts were under construction)
  5. #515
    Jul 2005
    Motorcity
    Blog Entries
    1
    And a couple of the "Button Key" which can be hot swapped.
  6. #516
    Dec 2007
    wow joe ... ur stuff never ceases to amaze me ... couple of questions ... 1. does the hard drive mount come with my chasis you are building? 2. any interest in fabbing up some sort of buttons for my dash since its identical to yours??? i have the same three empty spaces and would maybe like some hot keys there, and possibly a volume knob ... not sure if its possible or your willing but i thought it was worth a shot to ask
    thanks
    Zach
  7. #517
    Feb 2008
    i sent you a pm blk02si has anyone that talked to the guy that wired his comp into the stock shaker stuff gotten a wireing diagram of it?
  8. #518
    Jul 2005
    Motorcity
    Blog Entries
    1
    His name is JOvercash on the forums, Josh is his first name.
    He has all the documentation and knowledge about interfacing the shaker system.
    I didn't order the shaker system since I knew all the OEM stuff was coming out anyway.
  9. #519
    Feb 2008
    i cant find his user name on the member list has anyone talk to him recently?
  10. #520
    Low Bitrate gla502's Avatar
    Jul 2007
    I actually wired mine to my factory Shaker 500.
    - GA
  1. indash touchscreen vga rca inputs
    By mike86ttype in forum Classified Archive
    Last Post: 01-30-2005, 10:30 PM
  2. FS: Indash Unit from tm-701L
    By BoraXP in forum Classified Archive
    Last Post: 01-15-2005, 03:48 PM
  3. Cheap indash monitor
    By darkhavoq in forum LCD/Display
    Last Post: 11-21-2004, 03:01 PM
  4. FS: Complete Mini-ITX CarPC w/Xenarc Monitor + More
    By DLe in forum Classified Archive
    Last Post: 10-19-2004, 09:15 PM
  5. Nissan Sentra 1996 GXE Complete Project. 14'' Screen
    By criterzzz in forum Show off your project
    Last Post: 08-01-2004, 01:07 AM
