Page 62 of 78 FirstFirst ... 12525354555657585960616263646566676869707172 ... LastLast
Results 611 to 620 of 778
Thread: Complete bolt in Screen/CPU/HD/PS - indash
  1. #611
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    That motherboard you're choosing looks nice. Are you trying to keep the system low cost or are you looking at higher-end mini-ITX boards?
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  2. #612
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    @ Kalenth,
    Are you talking about the LCD controller cable? Looks to be orange in your picture. If so that cable is hard to work with on any of these screens, also very delicate, that's where an x-acto blade was my tool of choice, in locking and unlocking that ribbon cable holder. Its hard to seat it correctly and then lock down the holder. If its even .5mm off it will lock down but it won't work or will give erratic display. That's the part were patience is really the only way to get it.
    @galvitron, I am still looking at motherboards, as I really want to use an M3 power supply but I don't think the M3 has the extra 12volt rail for processors that use it. I am going to look into it a bit more, but motherboard deliberations are still in the works.
  3. #613
    Constant Bitrate Kalenth's Avatar
    Aug 2006
    DFW
    BLK, I guess all I needed was some encouragement. I played with the bar a bit, and finally figured it didn't just slide into place. Once I got it moved, I delicately reposistioned the board so the bezle would fit tight to the case, drilled, mounted, and everything booted right up. Feels good!
    Thanks again for that case, it just looks so clean.
  4. #614
    Jul 2005
    Motorcity
    Blog Entries
    1
    That unit looks nice! Its amazing how clean the glossy white epoxy finish can add to the aesthetics. How about a pic from the backside
    Also read up on your monitor of choice, its quite a bit more expensive, almost double what i've been paying for monitors, but the specs seem inline with the price. Let us know how it works in the sun, while driving, etc.
  5. #615
    Jun 2008
    looks nice! good job!
  6. #616
    Aug 2006
    DFW
    So far I have been very pleased. I think I'm going to bring the IR sensor through the bottom of the bevel, so I can adjust the monitor if necessary without moving all the buttons. Anyhoo, I'll edit this post when I get my work log started and link to that.
  7. #617
    Jun 2008
    Illinoise
    WOW!
    Read page 1 to page 42....... just getting started in the CarPC hobby. Lots of good stuff here. Thanks for keeping us informed!
    BTW your chassis kick a55!
    BTW: Building my system on a 945gclf w/Atom 1.6 now. I'll be sure to post results as they unfold.
  8. #618
    Aug 2006
    DFW
    Quote Originally Posted by SpecialEd View Post
    WOW!
    Just keep reading and researching, take your time. I've been researching this frikin thing for a year and a half, just now building. Gotta get something nice for the wife before I ship to Afghanistan.
  9. #619
    Constant Bitrate bl3nd3r's Avatar
    Jun 2006
    Pickering, Ontario, Canada
    Quote Originally Posted by blk02si View Post
    I just contacted up mini-box to ask them that question as I was hoping on using the M3 for Intel's new motherboard. They pointed me to this http://www.mini-box.com/4-Pin-P4-Power-Cable_2 Which is a molex to 4 pin 12v adaptor. Hope this helps.
  10. #620
    Mar 2007
    Socal
    Well the M2-ATX has that P4 connector but is of course much larger than the M3. You can always use a hard drive style molex to P4 plug adapter coming off of the M3's HD connectors...
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  1. indash touchscreen vga rca inputs
    By mike86ttype in forum Classified Archive
    Last Post: 01-30-2005, 09:30 PM
  2. FS: Indash Unit from tm-701L
    By BoraXP in forum Classified Archive
    Last Post: 01-15-2005, 02:48 PM
  3. Cheap indash monitor
    By darkhavoq in forum LCD/Display
    Last Post: 11-21-2004, 02:01 PM
  4. FS: Complete Mini-ITX CarPC w/Xenarc Monitor + More
    By DLe in forum Classified Archive
    Last Post: 10-19-2004, 08:15 PM
  5. Nissan Sentra 1996 GXE Complete Project. 14'' Screen
    By criterzzz in forum Show off your project
    Last Post: 08-01-2004, 12:07 AM
