Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 53
Thread: Started my 95 Tahoe Dash w/ 8" Touchscreen.
  1. #41
    Aug 2007
    Clean job, I have a 97 Hoe also and I'm gona do the same to mine. Where can I find the products that you used?
  2. #42
    Aug 2007
    Clean job, I have a 97 Hoe also and I think I'm gona go ahead and do the same. Where can I find the products that you used?
  3. #43
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    Quote Originally Posted by bring View Post
    goferauto.com
    http://www.levineautoparts.com/dursemplasre.html
  4. #44
    Nov 2006
    Worcester, MA
    Possible to find out some information about this?
    If the OP can chime in, What should I sand with? Was that a 4x4, where'd you put the controls, and what did you do to the AC harness to make it fit?
  5. #45
    Jan 2006
    The Colony, TX
    Quote Originally Posted by djtecthreat View Post
    He sanded from a low grit to a high git. body filler he used was rage gold. but he held the screen in place with Duramix4040.
    the ac the factory plastic bracket had to be slightly modified he used ABS plastic.
    do you not see the pictures? controls are obvious...
    screen name here use to be MegaloRESE15"
  6. #46
    Nov 2006
    Worcester, MA
    Yeah, you didn't really answer any of my questions. I asked what he sanded with (meaning what grit, and was it by hand or with a sander). I asked if there were 4x4 controls, and where he located them if there were. And i asked what he did to the AC "harness" to make it fit, meaning the plugs on the back.
    Pic's don't reveal any of this.
  7. #47
    Jan 2006
    The Colony, TX
    1. what he sanded with (meaning what grit, and was it by hand or with a sander).
    2. I asked if there were 4x4 controls, and
    3. where he located them if there were. And i asked
    4. what he did to the AC "harness" to make it fit, meaning the plugs on the back.
    I have seen his SUV before, he explained a lot of it he even did the work on my dash.
    1. this really shouldnt be a question honestly, you start from a very low git to get all the rough spots out then move on higher and higher to get it smoother and smoother. (Its more user preference if you get what I mean, but the "low to high grit" is a good guide to achieve the smoothness if thats what you are looking for) He did sanding by hand, the RAGe GOLD makes it extremely easy to sand which played a good part.
    2. iirc he had the basic model Tahoe, it didnt have anything fancy like 4x4 controls
    3. cant relocate something that isnt there
    4. he said he just took the connector part off the board(male side) to make the f-connector side fit comfortably with the dropped ac controls lower. i hope I worded that good.
    btw he no longer has this Tahoe he has an Acura now.
  8. #48
    Nov 2006
    Worcester, MA
    1. Better answer to the question, i guess.
    2. I have the basic model tahoe, which just so happens to have electronic 4x4 controls. This isn't "Fancy" its a way to switch the 4x4 on or off if you have it.
    4. My connector is actually part of the controls, (molded into the plastic) so that may not come off for me. Looks like more dremel work.
  9. #49
    Feb 2008
    That look great. Nice job.
  10. #50
    Low Bitrate jbraddoc's Avatar
    Feb 2004
    Dickinson, North Dakota, United States
    i know this is an oollllllld thread, but do you still have the pics for this? They aren't working and I am trying to get ideas about my 95 suburban. Thanks :-)
  1. Dash mount screen in GM Chevy Tahoe
    By slushieken in forum LCD/Display
    Last Post: 06-19-2006, 04:31 PM
  2. Xenarc 8" or Liliput 8" touchscreen?
    By mmdb in forum LCD/Display
    Last Post: 11-08-2005, 02:20 PM
  3. FS: Lilliput 8" touchscreen - Liliput TS
    By swissRv in forum Classified Archive
    Last Post: 08-03-2005, 01:33 PM
  4. In Dash VGA Touchscreen
    By haileris in forum Newbie
    Last Post: 02-17-2004, 05:34 PM
  5. longshot: any motorized in dash touchscreen vga LCDs
    By aoLhaTer in forum LCD/Display
    Last Post: 05-08-2003, 07:20 AM
