put a contact switch that will get pressed (and cut power)at full extension of your shelf. and then do the same thing for the lead that controls the reverse direction.
am i making sense?
I want to do this:
I want to create a shelf that will drop down and go back up with the push of a button. It needs to hold about 3 pounds or so too. I originally was going to try and use an actuator, bit they are way too expensive. I then thought a servo, my only two concerns with this are. One will it hold the weight, and two how do I get it to stop at a certain point.
What I mean is i will install a rocker button for forward and reverse, but how do I make the servo stop where I want it to stop. I only want it to open about two inches and stop and I also don't want it to close too far. I mean I guess I could just hold the button until it gets to where I want it but that would get annoying after awhile.
Here is where I was thinking of putting the servo:
am i making sense?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
I don't think a servo will be strong enough. I think you will need to spring for a linear actuator.
Michael
watcha gonna put on the shelf?
3 pounds of stuff... which will slide off 'cos the shelf is on a slope?![]()
2005 Nissan Xtrail
DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
worklog
No i'm going to attach it to the shelf...so a servo won't hold it? Any other ideas as to what I could use, those darn actuators are expensive.
Also...I don't have a ton of room to put a long actuator in. I was thinking pneumatic, but then I'd have to hook a pump up and everything.
I found some stuff on ebay for an air set up, what do you guys think...what else would I need to get?
http://cgi.ebay.com/Pneumatic-Mini-D...QQcmdZViewItem
http://cgi.ebay.com/Mosier-Tiny-Tim-...QQcmdZViewItem
http://cgi.ebay.com/2-in-Stroke-Doub...QQcmdZViewItem
get yourself down to the scrappy (US Translation : Junk Yard) and half inch (US Translation : Obtain) some window winder motors and actuators from some car doors.![]()
Like this:
http://cgi.ebay.com/ebaymotors/Brand...35113856QQrdZ1
Will it be strong enough?
What about a high torque servo like this:
http://cgi.ebay.com/NEW-Traxxas-REVO...QQcmdZViewItem
or hack apart a G glamp with a coarse thread and hook up the threaded rod to a motor with buttons to stop the motor when open or closed. Make sure you pivot the motor and threaded part on the shelf.
