Results 1 to 6 of 6
Thread: RC Car Shell as case
    Oct 2005
    I currently have a CarPC installed on my passenger side of my car, and I need to do something to spice it up a bit because it just looks to bland over there. After seeing the following links they have provided me with enough motivation to go through with the idea.
    http://mini-itx.com/projects/supra-server/
    http://mini-itx.com/projects/htpc/
    http://mini-itx.com/projects/htpc2/
    I'm going to run with it and try and make it happen. The shell I plan on using is the following:
    http://www.rcmart.com/catalog/product_info...roducts_id=6663
    With the dimensions of: Length - 9" (228mm) Width - 4" (101mm) and Height - 2-3/4" (70mm) it can work with little modification to the actual shell. However, would the components inside ever get hot enough to melt the plastic? The only difficulty I see with such a project is the mounting of the components, so that a bumpy ride won't damange them. Any help, opinions, insults are appreciated
    Constant Bitrate UnsanePyro's Avatar
    May 2005
    RI
    They often times have small engines running under them, but then again, they are usually moving, and have some sort of ventilation, maybe you could incorperate something with the fans for the board to get the heat out.
    :: '97 2.5 TL :: CarPC 1.0: Complete :: CarPC 2.0: 95% ::
    Variable Bitrate 12Vsystems's Avatar
    Mar 2005
    Orange County, CA
    it will really depend on the cpu. If you run a VIA C3 the components won't get hot enough to melt the plastic.
    Spent all my money on carputers now I have to work a real job.
    http://www.858graphics.com
    Aug 2005
    Near Buffalo, NY
    I used to be into nitro rc cars. The shells can be millimeters away from 300 degree fahrenheit heat sinks. So heat will not be a problem.
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    those bodys can take alot of heat but u still might want to throw in a small fan just to be on the safe side
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by Jcarere
    you mean heat will not damage the shell, right. Cause we all know the PC can be damaged by heat.
    TruckinMP3
    Read the FAQ!
  1. How to: Change windows shell
    By IntellaWorks in forum WinNT Based
    Last Post: 02-11-2011, 02:14 PM
  2. Employee Discounted Cars: Flatout BIG LIE!
    By sdashiki in forum Off Topic
    Last Post: 10-31-2005, 06:53 PM
  3. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  4. That new car smell...
    By PatO in forum Off Topic
    Last Post: 04-01-2005, 03:29 AM
  5. some pictures of my car and custom case
    By Awol][ in forum General MP3Car Discussion
    Last Post: 12-07-2000, 09:04 AM
