The screen itself isn't very thick at all. Maybe 1/2" or so thick. Although you'll need to extend some wires from various boards if you're going to mount the screen further away from them.
Hello people! im beggining to compile information together to create a motorized pop up screen for my car. Unfortunately i came to a small problem. I have a space of about 1 inch but when going through the different dimensions of the screen, i have found most of them to be too thick. Is there any way to make the screen thinner or is there a thin screen out there? I searched but i didnt find any relevant searches. Thanks guys/gals!
In the works...
Dell GX240 SFF
P4 1.8GHz, 256 RAM, 160GB HDD
8" Lilliput (fab work completed - F-150)
My worklog
Misc crap FS - OLD laptop (w/ adapters) | Sony memory | USB key | Printer Dock, etc
The screen is basically going underneath the dashboard so would that be safe at all? Would i have to make a new backing as well as housing for the other hardware? The screen that is the thinnest that i found seems to be about 1.38 inches. This may work but id rather get it slimmer so i could fit in the motor and so on. Thanks for your reply, more input would be greatly appreciated!
Im sorry i have to resort to this but.... BUMP...![]()
I really need help with this and im trying to get it done ASAP because its a school project. Any Ideas anyone?
The LCD about 1/2 inch thick. If you open the housing, there is the LCD and a controller board. The controller board is usually spaced away from the LCD. This sandwich, plus the plastic makes up the thickness.
If you want a thin LCD, you're going to have to fabricate and move the controller board further away from the LCD.
Is the control board the size of the whole screen or is it like half the size. Ive opened a monitor before and usually the chip or whatever isnt as big as the screen itself, but they just make the case big enough to accomodate a bigger chip. Is that the case? not sure if that really made sense... How hard is it to seperate the controller? Oh boy, this may end up being tougher then i had hoped. Thanks for the reply, any other ideas are totally welcome and appreciated.
Edit: i forgot to mention, if the top part of the screen is thinner then the bottom, that would work too. The top half just need not be more then about 1 inch. I cant see the backs or side view of the monitors so i cant tell if they are like that or are just a perfect rectangular box. Nobody seems to be interested in the back of the monitor except me. haha
This thread should answer most of your questions... at least in regards to a Lilliput.
In the works...
Dell GX240 SFF
My worklog
I just looked through all that and some of the related links within it, thanks! HOWEVER, i need to know the shape of the back of the monitor basically. Is it a rectangular box or is it like a monitor where the bottom end protrudes more then the top end?
Any side pictures of the screens would be greatly appreciated!
