Results 1 to 10 of 10
Thread: abs for molds?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    abs for molds?
    does anyone know if it is possible to use the abs sludge in a mold? are there any techniques i need to know of? are there any products that i can purchase that would cure faster then the abs sludge yet is desolvable with acetone so i can fuse it with my abs radio panel?
    thanks in advance.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Aug 2005
    Yes you can use it in a mold.
    You need to make sure to use a good release agent. PVA or any other specialized release agent should work fine. If you aren't sure what they are, use google.
    MEK might dissolve a little faster, but its going to take a while to dry regardless. The only way you could significantly cut down the drying time is to make it a compression mold where you impress a slightly proportionately smaller panel to the backside of the original mold, sandwiching the ABS sludge in between. Not easy to do, but it works well if you're going to be making quite a few pieces.
    In the works...
    Dell GX240 SFF
    P4 1.8GHz, 256 RAM, 160GB HDD
    8" Lilliput (fab work completed - F-150)
    My worklog
    Misc crap FS - OLD laptop (w/ adapters) | Sony memory | USB key | Printer Dock, etc
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Are you sure your radio panel is ABS and not PP?
    Aug 2005
    Should be ABS. The F-body (Trans Am) radio bezels I've worked with use ABS, so I would assume GM did something similar with the vette.
    To find out just look at the back of the panel. You should see an ABS stamp or a PP stamp.
    In the works...
    Dell GX240 SFF
    My worklog
    Apr 2005
    Boston, MA
    Quote Originally Posted by SMOKINV8
    Just thought I'd play devil's advocate before he gave it the sludge bath.
    Dec 2004
    Los Angeles Ca
    yup, abs. I alread gave it a sludge bath... this would be my third version of the install :-)
    As far as the release agent, i have some that i used for coating the original piece when i made the mold, i think it'll work while casting the new piece. Thanks for your help guys...
    if anyone knows of any other product...i'm all ears.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Apr 2005
    Boston, MA
    My days of serious molding were a long time ago (late 80s, early 90s). I remember Frekote had some good release agents for a variety of applications. Though I no longer remember which went with what
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by shotgunefx
    thanks... I just realized you're from my home state. I was born in Leominster, ever year of it?
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Apr 2005
    Boston, MA
    Quote Originally Posted by scott_fx
    Yeah, right past West Bum**** right? (Around here, they always jokingly called everything outside of 128 that )
    Actually I do know where it is. I remember I used to pass it going to the Wallace Civic Center when I was younger and went to a lot of shows. Though I think I've gone to Leominster for something else.
    Dec 2004
    Los Angeles Ca
    yup west bum...thats it! I used to play Hockey at Wallace...a long time ago
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. My try at ABS sludging a xenarc
    By evandude in forum Fabrication
    Last Post: 08-09-2006, 02:20 AM
  2. ABS Help?
    By awraynor in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-14-2005, 12:15 AM
  3. 100% ABS LCD install with texture
    By Snootch in forum Fabrication
    Last Post: 07-11-2005, 03:16 PM
  4. ABS plastic slim-drive/laptop drive surround?
    By beeman in forum Fabrication
    Last Post: 06-11-2005, 11:13 AM
  5. power inverter ruined ABS?
    By Parsec in forum Power Supplies
    Last Post: 08-11-2003, 08:08 AM
