Results 1 to 10 of 16
Thread: Repainting dash
    Constant Bitrate donde's Avatar
    May 2005
    Texas
    Repainting dash
    Several months ago I modified a junkyard dash to fit my truck and my screen. The dash was textured, so I had to fill in the stock texture with primer before I painted. After bondoing using a product called liquid plastic, I followed this procedure (I used all SEM products):
    -sand entire piece with 220 then 400 grit sand paper
    -clean dash
    -2 light coats of adhesion promoter
    -10 coats of primer
    -sand primer down with 400 grit sand paper to create a smooth surface (the primer had filled in the veins of the stock faux leather texture)
    -clean with water
    -3 coats of texture spray to create uniform texture across the whole piece
    -8 or so light coats of paint to finish it off
    The paint has held up just fine, but now I would like to repaint it as I have found some paint made by Ford that will exactly match my interior. My question is, do I have to sand everything off and repeat this entire procedure? If there's another way, I'd like to avoid the significant amount of time and materials involved, but I also want to do it right. The worse thing that could happen is I repaint it and in two more months have it start peeling. So what do I need to do?
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    sand the whole thing down with some 60 and then move up and up and up thats how i did it with my bike parts and stock dash works well
    Tainted Love Cris's Avatar
    Romania
    If you want do it right, you have to sand down the old paint.
    Constant Bitrate romul's Avatar
    Jan 2006
    i have a question very similar to this *sorry if you consider it thread jacking*
    The dash in my car is a pretty soft material, probably vinyl to pay it would i have to sand it or revinyl it? and if i paint it in SEM, wont it flake if i push hard on the dash and the paint loosens??
    **edit** donde, you have a very nice dash assembly
    Nov 2005
    There IS plastic safe paint stripper; Bumper stripper works with certain plastics (melted my abs dash though so beware!)...
    I ended up using Polly Scale ELO (easy lift off) which is made for use on model trains and such, worked excellant with some steel wool! I had my "textured" paint and the krylon fusion primer off in no time. AND it didn't eat my ABS Dashboard (that was underneath) at all.
    FYI I picked it up at a local model train/hobby shop for $11.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by romul
    SEM paints have a flex additive in them so they are designe to bend without cracking.
    there is a company that i used that will match oem texture and color. the company is called leather magic and they do great work.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Nov 2005
    How much did they get you for? (to "leather" the dash)
    Dec 2004
    Los Angeles Ca
    $65 and it was an exact match, even when taking a picture (usually that shows any difference in sheen or color) it matches perfectly
    stock:
    modified:
    M10k
    My Car Pc Install
    My Boat Pc worklog
    May 2005
    Mpls, MN
    wow, they do good work, as do you, thats a hella nice vette
    Jan 2006
    Quote Originally Posted by scott_fx
    you sent them the whole dash ? and they recovered it or you used one of their products?
  1. Help on custom dash for Caddy STS
    By Slaughterhouse in forum Fabrication
    Last Post: 12-14-2006, 07:47 PM
  2. 3rd Time's the Charm??? Mercury Cougar Dash Lilliput
    By antimatter in forum Fabrication
    Last Post: 08-07-2006, 01:21 PM
  3. trying to mould dash.... pls advise...
    By CA 3000GT in forum Fabrication
    Last Post: 06-07-2005, 06:51 PM
  4. 2003 Altima Dash Fabrication
    By in4no in forum Fabrication
    Last Post: 02-11-2005, 11:51 AM
  5. In dash or Not in dash that is the question
    By belezeebub in forum Fabrication
    Last Post: 12-10-2004, 06:18 PM
