Results 1 to 10 of 12
Thread: Taking a mold
    May 2005
    Taking a mold
    Anyone have any suggestions on how I can take a mold of the roof without using fiberglass?
    All I really need is the contour of one part, so I can make a template for my overhead console.
    Here's a drawing to explain more clearly. What I need is that black line..how can I get the curves to match the curves in my headliner?
    Any ideas?
    Take 2 - '03 Audi A4
    macmini with an 8" widescreen (in progress)
    My 2004 Ford Ranger:
    14" LCD w/ custom made aluminum bezel
    Completly custom computer case
    status: Totaled
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Plaster of paris (casting plaster).
    My suggestion would be to get the banadges they use (or used to use) for making plaster casts from broken limbs.
    May 2005
    Quote Originally Posted by Enforcer
    but how would i hold it to the ceiling? I think i would have that same problem with fiberglass, it'd be hard to make it hold to the ceiling of the headliner
    status: Totaled
    Newbie bigrobb's Avatar
    Nov 2004
    cardboard template?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Rocky388
    You would need to wedge it in place, with a piece of wood and some poles probably.
    or turn the car upside down and let gravity help.
    edit, what I would suggest is put some masking tape (or something to act as a protective narrier) on first, then whatever material you make the mould out of on top (or in this case on the bottom)
    Jan 2006
    my suggestion is to not get the shape of it, leave it open to the headliner where the black line is and just have the only place where it actually touches is on the edges
    May 2005
    Quote Originally Posted by Namor
    That's exactly what I plan on doing. It was just a bit hard to explain lol. In the drawing, the only part that's going to touch, is actually the side of the console, but what has to match is the curve of the black line.
    I tried making a cardboard template, but it's not really going to plan. I was hoping there was a more exact way I can do it.
    I guess I could just take out the headliner, and make a mold of that with fiberglass.....but I hate fiberglass
    status: Totaled
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    How big an area is it?
    Plaster could be worked (even upside down), but it's messy as all hell. You'll have plaster drops everywhere. You can speed up the drying with warm water (and salt will quicken it further I believe).
    If it's not that big, I'd heat a sheet of abs at ~ 250 for 10 minutes or so, wear real heavy gloves. Remove it from the oven and try and press it against the ceiling before it cools. Don't drop it on your face
    May 2005
    Quote Originally Posted by shotgunefx
    It's not that big (no bigger then 2 feet x 1 foot, and i'll be making it smaller too) but i would imagine doing that would destroy my headliner. I'll keep that idea in mind if I have to take a mold of the actual roof (the metal part)..which i might have to do to make a mount for this hole thing.
    status: Totaled
    Apr 2005
    Boston, MA
    It might. But if you heat it right it's shapable, but not melting.
    My concern would be that most headliners are meant to shrink up from flame (maybe heat too) in case of a fire. That's why you get those damn awful scorch marks instantly if someone is smoking and an ember hits it.
    You could also get those foam "rulers" for recording the shape of something (they use them in body work) and try and recreate the curve. with some balsa wood. That sounds hard though.
  1. Does anyone want to build a fiberglass mold?
    By SecretSpyder in forum Fabrication
    Last Post: 11-09-2007, 05:10 PM
  2. I'm taking a break
    By febsperanza in forum FrodoPlayer
    Last Post: 02-01-2005, 04:26 PM
  3. I'm taking a break
    By febsperanza in forum NeoCar Media Center
    Last Post: 01-27-2005, 04:57 AM
  4. Making a mold after dash customize ??
    By Don 944 LA in forum Fabrication
    Last Post: 11-06-2004, 04:41 PM
  5. question about making a mold
    By zaxxon in forum Fabrication
    Last Post: 07-29-2004, 06:36 PM
