Results 1 to 6 of 6
Thread: What should I do?
    Apr 2005
    Queens, New York
    What should I do?
    Hey guys whats up, I am going to be molding my headunit down below where my ash tray is and cig lighter. I have a pic of someone who actually molded there HU there. They took an aftermarket HU installation kit and molded it it.
    Now my question is, How should I go about molding the installing kit in? Should I use bondo? I have never fabricated anything before....Sp what are the steps to take? Basically just bondo it and then sand? The prime then paint? What type of stuff is good? And where should I go to get it?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Maximum Bitrate Meatballman's Avatar
    Jul 1999
    Hartsville, SC
    Unfortunately, someone asks the same thing just about every other day in here. You'll have a hard time getting any answers unless you do some research and ask specific questions. All the answers you need are in this forum, so I'd recommend you start looking through the threads or do some searching.
    As far as your question goes, just bondo is a bad idea. If you want it to last, you'll need something more structural like ABS goo or epoxy or even fiberglass for larger openings. A good place to start off your research would be here.
    EDIT: I see you're not a newb to the site...shame shame
    Apr 2005
    Queens, New York
    Quote Originally Posted by Meatballman
    HAHA lol!. Where can I obtain ABS goo? I am looking for it but cant find it, Is ABS Goo the proper name, what companies makes it
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Constant Bitrate Matrix_24's Avatar
    Jul 2005
    IL
    Quote Originally Posted by Cheekz185
    I would not use bondo to build the structure. I used Bondo Fiberglass resin and it turned out very nice. I built the frame and used some foam from a craft store (the hard foam not the packing type). It is rock solid and I am happy with how it is turning out. Look at my Durango install in my sig.
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Did you read that thread at all?
    You don't buy it, you make it. The basic recipe is.. ABS plastic shavings and Acetone.
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    hey cheeks show me a stock picture down there... you can prolly fiberglas a mold of the cubby thing and build upon that
