Results 1 to 10 of 18
Thread: How to cut perfect rectangle in plastic plate?
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    I have a plastic switch plate (about the size of a radio faceplate) that is 1/8" thick that I want to cut an inner rectangular hole in, which will essentially make the plate a frame (maybe a centimeter wide all around).
    My question is what's the best way to do this, with the end result being a rectangular hole with perfectly straight lines/sharp corners? I've been using a thin fine-tooth hacksaw blade, and the cuts aren't straight.
    Feb 2006
    Westfield, MA
    If you have access to a bridgeport, you can use an endmill and sharpen the inside corners with a file. It will be a perfect rectangle.
    Jan 2006
    Michigan
    I bought a Dremmel and it had a router attachment. You can make up a jig to run it against to cut out a perfect Triangle ... oops, circle ... oops , octagon ... Rats, you know what I mean,
    lol
    Variable Bitrate kmcniece's Avatar
    Aug 2004
    Portland, Oregon
    There is a company that will do Custom fpanels/plates for pretty cheap. I can;t remember the name, but i will look it up for you when I get home late tonight. IIRC, they will laser cut plastic and metals for you, kind of like Emachine shop, only cheaper and only 2D pieces.
    Edit:
    www.frontpanelexpress.com
    Otherwise, a router/dremel w/router attachment would be the way to go. Actually a bridgeport would work as well... You got options..... a hacksaw though, no thanks.
    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
    Status:
    Installed & Working....
    Custom enclosures
    Newbie Guide
    Feb 2005
    Atlanta, GA USA
    Wow, what a great link - thanks!
    Newbie agmsd's Avatar
    Oct 2005
    That's a nice link... anyone knows another link for someone who does plastic?! it would be nice...
    Aug 2004
    Portland, Oregon
    www.emachineshop.com does plastic. I thought front panel did plastic as well.
    Status:
    Custom enclosures
    Newbie Guide
    Nov 2004
    nice sites
    Nov 2005
    Really all you need is a router. Start by making your template out of mdf. Then once you have the shape you want, attach the piece of plexi to the wooden template with double sided tape, and run it around your router. That is how I did the plate on my console.
    May 2005
    or, if you're patient, you can use a hacksaw and rough cut it, then fine tune it with a file. That's how I did my aluminum bezel..but depending on the plastic it might be too flimsy to file.......
    mine as well give it a try though if you already started with a hacksaw.
    Take 2 - '03 Audi A4
    macmini with an 8" widescreen (in progress)
    My 2004 Ford Ranger:
    14" LCD w/ custom made aluminum bezel
    Completly custom computer case
    status: Totaled
  1. Plastic Welder - anyone used?
    By evandude in forum Fabrication
    Last Post: 11-15-2010, 11:55 AM
  2. False floor
    By i3igmind in forum Fabrication
    Last Post: 02-04-2006, 11:28 PM
  3. best way to cut plastic?
    By TxMazda3 in forum Fabrication
    Last Post: 02-12-2005, 09:17 PM
