Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Plexiglass etching solutions
    Constant Bitrate tangeray's Avatar
    Mar 2005
    Chino Valley, AZ (2 Hours north of Phoenix)
    Hi everybody. I made an amp enclosre thats flush with the floor of my trunk , putting the amp in the spare tire compartment. I want to cover the viewing hole with a peice of plexiglass which is allready fitted....
    --My question is that is there a quick chemical solution to etch or "frost over" some plexiglass? Maybe give it a tiny bit of depth? I want to etch the infinity symbol on the plexi. (infinity audio symbol that is). Any ideas without going to outside sources would be awesome? and if I have to go to outside sources, about how much would something like that cost me??
    Thanks,
    Tangeray
    Variable Bitrate viper24's Avatar
    Oct 2005
    Sacramento, CA
    Im pretty sure laser etching is cheap. id say like $20 or so... my local plastic shop does it for cheap cheap (Tap Plastics)
    2005 Dodge Ram HEMI
    http://www.cardomain.com/ride/2239451
    15" LCD touchscreen
    Mac Mini
    6" Headrest monitors
    Modded Xbox
    5 PSone screens going in doors
    And another 15" LCD!
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you could make a template and then spray over it. they have some smoke effect sprays on the market. or you could cut it out of frosted contact paper and apply that.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Sep 2003
    Austin, TX
    Yeah you could just grab a can of plastic/glass frosting. It's just clear-white spray paint. Not as fancy as etching, but it works.
    Nov 2004
    When I was younger we did Glass etching, on mugs, glass, mirrors etc.
    It was with a etching paste.
    anything the paste touches it turns to a frost look.
    So all you do is do a design on a stencil and apply it to your glass (Not sure if it will work with plexiglass)
    As long as you like to DIY then here you go.
    Here is a link I found using google.
    http://www.glass-etching-kits.com/gl...structions.htm
    Jul 2005
    Quote Originally Posted by viper24
    I think that plexi is not really suitable for lasering, because of the fumes it gives off... same for PVC pipe and other noxious plastics. There is risk of damage to the laser (hot, nasty fumes attaching to or fusing with mirror / lens subsystems) as well as the operator (stinky-poo!)
    Acrylic, on the other hand, is an entirely different story. Most decent laser can cut it to precision, as well as etching patterns into it.
    I am building a business around a laser engraver soon, and will need to prepare some samples...
    FLAC djmickyg's Avatar
    Feb 2004
    u can mask off the area u dont wanteffected.. or get some sticker made up to cover the area and use and sand blast it using fine glass beads.. the finer the beads the less impact it will cause.
    ectching pasts on plastic i wouldnt think would work to well.. the'll melt it i would think.
    May 2005
    my friend at www.minitruckstickers.com makes vynal decals and yes you can make sickers that go on glass/plexi to give the look of frosted/etched look might be a cheaper way to do lots of designs
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Quote Originally Posted by geekasaurus_rex
    Um... plexi is acrylic. "Plexiglass" is just a brand name.
    Jul 2005
    Quote Originally Posted by mushin
    Alrighty then. My apologies.
    I do know that the PVC is a no-no. Additionally, isn't most plexi a little on the thin side for doing this type of "beauty" work? That is, most plexi is 1/16" or 1/8" on this high side, where the previous photo was 1/4" or 1/2"?
    (Throw me a bone here... I am trying to save at least a little face!)
    Thanks.
  1. plexiglass case
    By warnockm in forum Fabrication
    Last Post: 08-04-2005, 03:30 AM
  2. Custom Plexiglass case
    By sxt173 in forum Show off your project
    Last Post: 04-18-2005, 12:37 PM
  3. Making Designs in Plexiglass
    By HHdesign in forum Fabrication
    Last Post: 03-28-2005, 09:50 AM
  4. FM radio on your PC solutions
    By linden_arden in forum General Hardware Discussion
    Last Post: 01-29-2005, 09:07 PM
  5. plexiglass question
    By Squeezer in forum General MP3Car Discussion
    Last Post: 07-23-2003, 02:48 AM
