Results 1 to 3 of 3
Thread: Lilliput bezel broke away from console
    Sep 2005
    I don't have pictures, but during my trip into work this morning, my lilliput broke away from the plastic putty I used to connect it to the center console of my car. The plastic stuff didn't detach from the console. Did I do something wrong? Do I need to apply some sort of adhesion promoter to the bezel of the lilliput? Did I not have a thick enough layer between the console and the bezel? I'm not all that worried about it - I'll just sand down the stuff again and try it over. I did notice when I sanded the last time there were places I sanded the finish right off the bezel. I'm wondering if I needed to do that everywhere because it looks like that is much more pourous than the finish of the bezel. Should I use fiberglass, or the abs sludge type stuff? Not a bad lesson to learn, just a temporary set back. Thanks!
    Low Bitrate Ub312g0d's Avatar
    Feb 2006
    Toronto Ontario
    I think pictures are needed to help out your situation. Did you only use bondo to attach the bezel to your dash? regular bondo(body filler) is not supposed to be used to hold things together, just to fill imperfections. You might want to look at fibreglass reinforced filler.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    You have to thoroughly sand EVERYWHERE any adhesive, primer, paint, etc. is going to be applied.
    Fabricator
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. WTB: 7" Lilliput project housing/front bezel
    By kamikaze2112 in forum Classified Archive
    Last Post: 09-28-2005, 05:58 PM
  3. 56K beware** Sunfire lilliput
    By Moneyfink in forum Show off your project
    Last Post: 06-29-2005, 08:53 AM
  4. WTB: Lilliput Front Bezel
    By [iG] in forum Classified Archive
    Last Post: 06-25-2004, 03:11 PM
  5. del
    By hanzacra in forum Classified Archive
    Last Post: 03-25-2004, 05:44 PM
