Results 1 to 10 of 12
Thread: Any way to bond an ABS sheet to an aluminum sheet?
    Constant Bitrate 01black_ac's Avatar
    Jul 2005
    NJ
    I'm starting the fabrication of a custom frame for my headunit and MTSVO-SC retractable screen. It seems like the hardest part is going to be mounting the burlwood trim ABS sheet onto the metal frame which will house the headunit and screen. Is there a way to permanently bond a sheet of ABS plastic to a sheet of aluminum (or steel) and not have it come apart from changes in temperature or driving vibration? I could always use a set of countersunk screws, I suppose, but my first choice would be to have it appear completely seamless, with no screws on the visible surface. Any ideas out there for cementing ABS to metal?
    '01
    Hang on while I defragment my car...
    the Acura ITX project
    the Acura ITX skin for RoadRunner
    project progress: 99%
    Feb 2006
    I'm kind of bias to fiberglass resin. I'm kind of fuzzy on your application, but believe it or not, i've seen silicone make an amazing hold onto aluminum, and it held in the outdoors for going on three years. Just a thought.
    Aug 2004
    there are adheasives that are used on cars that will work
    Feb 2006
    PL Premium construction adhesive, comes in a caulk gun tube and maybe/possibly and squeeze tube. the shiite sticks to everything. If one of the two surfaces aren't porous it'll take a while to dry/cure. There's also some two part auto body glues that are incredible, called Duramix.. look it up.
    Variable Bitrate jthiani's Avatar
    May 2005
    Raleigh, NC.... Nbi, Alpha quadrant (1 00 N, 38 00 E ) !!!
    Quote Originally Posted by furball69
    I concure !!!!!!!!!!!! Construction adhesive does stick anything to anything !!! Period. You could also try silicone if you need flexibility since it dried to a flexible rubbery conpound. 86 the fiberglass resin.....it will not hold on to the plastic of metal !!
    May 2005
    lately I've been using crazy glue for just about everything . About a month ago I glued a piece of aluminum to the front of my DVD player draw. I was pulling on it and pushing it, and it's on there pretty firm..I'd give it a try.
    Take 2 - '03 Audi A4
    macmini with an 8" widescreen (in progress)
    My 2004 Ford Ranger:
    14" LCD w/ custom made aluminum bezel
    Completly custom computer case
    status: Totaled
    Variable Bitrate Freelander's Avatar
    Jul 2005
    NYC
    Quote Originally Posted by Rocky388
    a few months ago i temporarily built my enclosure for my screen with crazy glue and abs cement. i took it out yesterday to rebuild it. since it was baking in the sun, the pieces practically peeled apart.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    I've been quite impressed with JB weld. Just used it to glue my aluminium screen bezel together after trying (and failing) to soldering it. JB weld seems to stick to anything quite well.
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    I'd give Raycrete a shot. I love this stuff.
    Got an order for a gallon coming next week. Besides that it's easy to use and work, it's non-toxic, no cat-**** smell like epoxy, and it cleans up with lemon juice.
    Some places sell small packets of it for ~$5
    Newbie [HoP]'s Avatar
    Sep 2005
    Liquid Nails
    i work for the company that makes liquid nails (ICI) we dont make it at our factory but i have used this particular product!
    http://www.liquidnails.com/ViewProdu...o?productId=48
    you can find it at your local home improvment store (we deal to home depot mainly though)
    i used it on a plackard (the number of our apartment) that i wanted to lock to the door since it had fell off after the double sided tape ripped off the paint, it was bare wood meeting plastic. nonetheless it is stuck forever.... i tried to pull it off using a butterknife only to bend the knife (and it wasnt a thin one either)
    careful with the stuff (i prefer the non clear as i have noticed it to be slightly stronger) probably the different base used, but both are high strength and would last forever...
    *******DONT USE THIS STUFF IF YOUR NOT SHURE YOU WANT IT TO BE PERMINENT*******
    1999 Chrysler 300M
    Currently: Several Additions Being Made (My Main Vehicle)
    1984 Chevrolet Corvette
    Currently: Garaged N> Transmission Work
    1974 Toyota Land Cruiser
    Currently: Runs Good (Chevy Engine,Tranny,Transfercase) N> Body -Its Been Rolled-
  1. My try at ABS sludging a xenarc
    By evandude in forum Fabrication
    Last Post: 08-09-2006, 02:20 AM
  2. Salvaging my ABS sludge install with fiberglass?
    Last Post: 02-11-2006, 07:22 PM
  3. 100% ABS LCD install with texture
    By Snootch in forum Fabrication
    Last Post: 07-11-2005, 03:16 PM
  4. Replies: 34
    Last Post: 08-13-2004, 09:04 PM
  5. WTB : Sheet of Brushed Aluminum
    By arcane004 in forum Classified Archive
    Last Post: 02-05-2004, 01:17 PM
