Page 1 of 8 12345678 LastLast
Results 1 to 10 of 80
Thread: 91 Toyota Supra Fabrication
    Low Bitrate dsballer2000's Avatar
    Oct 2005
    Canada
    After reading this forum for almost a year now I've decided its time to just go for it and start my fabrication. I've heard about all the hard times this bezel has been with other users so I wasn't really excited about trying.
    The screen I decided to fabricate is the ever so popular xenarc 700tsv.
    At first I was going to use the bondo method but decided to try something different because Matrix told me about his cracking in different weather conditions. I'm in Canada so we have crazy weather with hot summers and super cold winters. For this reason and after reading a lot of threads, I've decided to use a method mentioned by Turbocad which is the Plastic repair kit method.
    I have never fabricated anything and I am new to this whole thing. I was told to get a professional to do it because I'm not experienced in this but I want to prove them wrong so it begins.
    This is the bezel and screen and xenarc shell I'm working with. The bezel says PP+PVC on the back.
    Oct 2005
    Canada
    Supra fab
    This is the Plastic Repair Kit I bought at Canadian Tire.
    Contents:
    1 Part A Semi-Flexible Epoxy Tube
    1 Part B Semi-Plexible Epoxy Tube
    1 Fiber Tape
    1 CA Weld
    1 Fast Cure CA Activator
    Oct 2005
    Canada
    Cut bezel
    Notice the rubber like outter material. This is the pain in the *** material that has been causing problems for most of the supra fabrications so I'm crossing my fingers
    Xenarc shell fitting
    Oct 2005
    Canada
    For some reason my camera didn't keep the pictures of the first layer of plastic. But after applying, sanding and sanding, and some more sanding and more applying. This is the results so far. I applied a little more over the imperfections but have yet to sand it down. It was getting cold outside so I had to clean up. I will sand this down tomorrow.
    This stuff is very easy to use. It applies on thick and hardens in 10-15 minutes. Sanding is a breeze and very forgiving.
    These are the results of about 2 hours worth of work. I'm pretty happy with it so far.
    Filling in where the cig lighter was took the most applying and sanding. As you can see I have a lot more sanding to do tomorrow.
    Oct 2005
    Canada
    Well that's it so far. Any critism would be greatly appreciated. I want this done right so I want to hear what people have to say. Thanks for checking out my thread and keep posted.
    Variable Bitrate skippy911's Avatar
    Feb 2005
    Lookin good so far. I went with the abs sludge method and am waiting for my newest coat to dry. Seems to take about 12 hours to fully harden and I have no clue how hard it will be to sand. If I ever venture into this again im gonna try your method because I am very impatient hehe.
    Oct 2005
    Canada
    Ya this method was great for no wait times. I could have sanded right after i applied the last coat if it wasn't so damn cold outside.
    12 hours to wait would be way too long. Oh well, hope yours is worth the wait.
    Feb 2005
    Yeah me too. I just went out and added a lil more to the open sections. Ill leave it till the morning to dry and then start sanding my first coat. What grit paper did you use to sand??
    Oct 2005
    Canada
    I'm using 120grit on mine but like i said, this stuff is very easy to sand. I've never done anything like this before so I'm learning as I go.
    Oct 2005
    Canada
    More Sanding
    As you can see, I sanded down the extra plastic I put on yesterday. I need to go to the hardware store and grab higher grit sand paper and some paints.
    I still haven't decided what will go at the bottom but I'm thinking a slot load DVD burner and usb ports as well as relocating my cig lighter down there.
  1. WANTED - Toyota Supra 1990 Roof bars
    By tracysupra in forum Classified Archive
    Last Post: 11-01-2005, 07:22 PM
  2. Replies: 7
    Last Post: 05-21-2005, 05:43 AM
  3. Toyota Supra TT mkiv
    By spyda in forum Show off your project
    Last Post: 02-21-2005, 06:08 PM
  4. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
  5. Error #91
    By SiGmA_X in forum ME Archive
    Last Post: 01-08-2004, 10:40 PM
