Results 1 to 6 of 6
Thread: what to cut with and how to do it right?
    Dec 2005
    Okay, so I know nothing about fabrication and had that in mind when planning my current carputer project. I decided to go with an in-dash motorized screen so I wouldn't need to cut and bondo much since I'm pretty sure I'd screw up my car somehow. Only after buying the screen did I realize I'd have to do some fabricating anyways to get that AND my head unit (both single din sized) in a 1 1/2 din opening. So I braved it and hacked away at the stereo slot in my dash and with some touchup bondo, I installed/secured it semi-satisfactorly. The only thing is now I have to widen and cut the opening on the dash faceplate (is there a name for this piece?) and I'm scared. Because if I screw this up, not only will it be obvious to anyone who sits in the car (and will look ghetto), I have no idea where I'd get another nor do I want to have to buy one or others. My major question is this; what kind of tool is best to cut through this accurately? (it's plastic, semi thick) My fear is using something that (a) won't make a clean cut and (b) using somehting that is too powerful and if I jerk suddenly while cutting, I'll screw it all up. Where to begin?
    Thanks in advance.
    Mar 2006
    Colorado, but Canadian!
    I'm still in the processes of my fabrication, and I too am scared as hell of messing something up and it looking ghetto. So I bought a spare piece for every part of the dash that I would be hacking up. If I screw up, then I just pop in the original. I got my parts from eBay. Also I needed 1 part that I couldn't find on ebay ( ) so I went to local dealership. They didn't screw me over either! Only about $2-$3 more than I thought it would.
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    How much do you have to widen it?
    2k1Toaster, I'm with you. On some parts, I had 3 or 4 of them for my modding projects, though I sold a bunch, cause, come on, who needs 4 gauge clusters
    Constant Bitrate blacklancer's Avatar
    Nov 2005
    Los Angeles, Ca
    i was just about to sell some of my interior pieces and decided to keep them to cut up. i would suggest getting another piece just incase.
    it depends on how much you have to remove really. if its a small amount and you're really scared of cutting, sand it or file it down. it gonna take longer, but you should feel more secure about doing it that way.
    Apr 2005
    Boston, MA
    If it's a small amount and not too thick, you can use a "plastic nibbler", radioshack sells one. Basically nibbles a small square with each squeeze of the handle. You'll still probably need to sand out the resulting line though.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    if it's small...sanding block and/or file. will allow you to work slowly so you wont overcut as well as giving you a straight edge
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. How Can I Use Half of the Old Sproggy PS
    By Wiredwrx in forum Power Supplies
    Last Post: 11-02-2003, 08:40 PM
  2. Nokia 3650- How good in the real World?
    By cafn8 in forum General Hardware Discussion
    Last Post: 10-21-2003, 10:13 AM
  3. Radio With MediaEngine
    By masterlp in forum Software & Software Development
    Last Post: 09-11-2003, 02:31 AM
  4. How much of the forum do you read?
    By MP3DUB in forum Off Topic
    Last Post: 11-06-2002, 08:32 PM
  5. Replies: 12
    Last Post: 12-04-2001, 07:36 PM
