Results 1 to 3 of 3
Thread: How do I get nice edges when cutting sheet metal?
    Feb 2006
    I have to extend the case on my carputer. I want to cut some metal off an old pc case to use. I have tried this with a hacksaw before, and got ugly uneven edges. Is there a much better way, that don't require tools that cost more than the carputer?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    draw file them agaisnt a straight edge clamped to the side after cutting. You should always draw file after cutting.
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    even sheers will leave nasty edges,
    when i did the aluminium for my case(desktop, not my carpc) i cut it slightly larger(maybe 1/16inch) and sandwiched it between two pieces of hardened steel, then i ground down the edges with a die grinder, got beautiful results, i then rounded with 120 grit sand paper, so to have a nice round edge there. worked great.
    eventually ill get a guide on detailing this process...
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
  1. Any way to bond an ABS sheet to an aluminum sheet?
    By 01black_ac in forum Fabrication
    Last Post: 05-16-2006, 05:42 PM
  2. Metal cutting, fabrication shops around LA?
    By cyberdrakon in forum Fabrication
    Last Post: 01-16-2005, 05:57 PM
  3. Metal Molding..Bending...Cutting...etc Services
    By PhongZ in forum Fabrication
    Last Post: 08-26-2004, 08:16 AM
  4. Replies: 22
    Last Post: 07-30-2004, 10:58 AM
  5. Replies: 13
    Last Post: 05-13-2004, 06:30 PM
