well im guessing its very similar to the 98 to 99-00 climate conversion that is if it can be done.. ive never seen it, from wat ive heard its a very long process personnaly it sounds like a realy ******
Hi All,
This is my first post on the site, although I have been following the forums and learning a great deal from all of you on here for about a year now.![]()
I have searched all over and could not find any info on whether or not the climate/audio control pod from the 2000 civic will fit in the 2000 Acura 1.6 EL (Canadian and Japanese only). I do not own the EL yet, but am looking at getting one and would like to use the bezel from the civic since it's so easy to fit a touchscreen in there (the EL bezel is more like the 96-98 civic's). Don't know if it would require a complicated swap like the 96-98 to 2000 that I've seen others do on here...
I am deciding between a few cars now and the ease of integration of a car-puter is one of my deciding factors. I am attaching a pic. of the bezel from both the Civic and the Acura.
Hope somebody out there can help, Thanx!
Not sure if you've seen this or not but maybe it will help you out a bit: http://honda-tech.com/zerothread?id=605432
Swapping from a manual climate control to full electronic like in the 99-00 civics is a bit of a process. Take a read through that, maybe it will shed some light on the subject for you. It's from 99-00 civic to 96-98 civic, but the acura 1.6EL climate controls are very similar. You'll have a hell of an easier time getting a 7" screen into the 99-00 than the 96-98 though.![]()
I have a 1.6EL as well. Any updates?
