Page 27 of 27 FirstFirst ... 1718192021222324252627
Results 261 to 267 of 267
Thread: Starting Fiberglass sub box!
  1. #261
    Jul 2009
    So today I finished the 6th layer of the base mold. Tomorrow I will cut the MDF wood and set it up for my subwoofer, then spread fleece over that and soak it in epoxy. Then put about 4-5 more layers of fiberglass on top of that. So I'm pretty much mimicking what pcmofo did with his build. The whole thing should be done by Friday hopefully.
    Here's my base mold:
  2. #262
    Newbie bad_luck's Avatar
    Jun 2009
    Heerlen, Netherlands
    i'm doing about the same for my girlfriends car:
    I'm nog sure yet if I'm going to make a flat front (just MDF) or a nice and beautiful round shape. Flat is surely easier, so I think that'll be it.
    When this one is done, I'm going to do the same in my civic
  3. #263
    Jul 2009
    Install finished
    Ok so I finally finished the box and it looks pretty nice if I do say so myself
    It hits harder and cleaner than my old bandpass and I really like it. Pics below.
    It's a tight fit and the hinge on the trunk hood barely misses the top of the box, but other than that, it fits perfectly.
    The amp isn't hooked up here because I can't decide where I want to put it. It was hooked up and playing before this pic though.
    So what do you guys think?
  4. #264
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    Damn... that looks clean... and the carpet to match... Now I wanna do that for my 2 8s.
    After a 2 year break, I'm back! There are so many new and familiar faces here!
    New vehicle, new ideas!
    Chryssi - The Changeling CarPC Project
  5. #265
    Jul 2009
    Yeah I was lucky to find some carpet that matches my trunk. In Wal-Mart, of all places. If you decide to build one for your 8's, post some pics of the process. I'd love to see how it turns out. Good luck!
  6. #266
    Jun 2009
    I completed this one, next is going to be for my own car.
    glued and screwed in the mdf front:
    then i made everything close air-tight with some fibreglass in the corners:
    and the result, with fleece on it:
    Really made the trunk a lot bigger ! Now it's easy to put groceries in it
  7. #267
    Sep 2009
    Quote Originally Posted by pcmofo View Post
    No one makes pre-cut MDF rings. Though that would be sweet. I was going to have someone cut mine but it cost way to much. I would use a router if you can but a scroll saw or something. You can do it pretty rough of a cut and clean it up until the sub fits. Its all going to be hidden anyway so it doesnt have to look nice.
    Actually, you can get precut rings online:
    http://www.roadgiant.com/metrathe-in...eakerring.aspx
    Just search online for "mdf speaker rings" Those ones are $4.88 for a 12" ring that is 3/4" MDF
  1. Fiberglass Alternative?
    By FiReToY in forum Fabrication
    Last Post: 04-24-2008, 09:24 AM
  2. Before putting fiberglass in trunk for sub box...
    By Seabass in forum General Hardware Discussion
    Last Post: 10-08-2006, 02:30 PM
  3. Salvaging my ABS sludge install with fiberglass?
    By evandude in forum Fabrication
    Last Post: 02-11-2006, 07:22 PM
  4. Replacing Dash Piece: Fiberglass or Wood?
    By fatejd in forum Fabrication
    Last Post: 01-17-2006, 12:02 AM
  5. Sub box rattling!!!
    By ddt in forum General MP3Car Discussion
    Last Post: 04-07-2003, 11:28 AM
