SOOOOO
I've been following this, and i'm thinkin about making a sealed box, and then putting a fiberglass design that goes over/around this box (probably with foam, but still...) and then covering it with a black vinyl material for a leather look.
ok... fiberglass resin, and hardner. is this like expoxy? must mix for it to activate?
when he refers to soaking things in apoxy to harden it, what is the "apoxy?" Does he mean the fiberglass resin/hardner combo?
fiberglass matte - fiberglass cloth - wool
for my application, (correct me if any part seems wrong, or an easier way) I think am going to use foam(suggestions on type?) and shape it around the mdf box, since the f/g itself isn't the box.
To reshape foam, I hear you need to prime it before using bondo, because it will eat away the foam?
So I glob it all up with plenty of bondo *(w/ the fibers, kitty hair or whatever) and shape it with, something like a putty knife and a grater, then sand smooth...
then, do I need f/g cloth, or just layers of resin on top of the bondo?? also, is there a way to mix coloring in with the resin to give color a deeper appearence in case I decide not to wrap them??
Then for the 6.5 speakers, I'll use the mdf circle and pull... wool?? right?... over it to form the curves and meet up with the foam before it has resin, apply resin, and then layer on my matte or cloth... does it matter? is starting with matte and then going to cloth a good idea?
for my aplication, I'd think a couple layers of matte, and then a couple layers of cloth will be good, especially since the speaker will be in its own box, and the only thing the f/g will be supporting is 6.5" coaxials on each side of the box.
This fiberglass is meant to cover the entire rear deck under my rear window in my 06 sentra SeR... the whole thing doesn't need to be fiberglassed, cause I can just pull vinyl over the flat surfaces, but still, most of it will be f/g... so I'll need to mess around before I go for the real thing. Give me some tips guys... this seems a little different considering i'm making a sealed box out of mdf and then fiberglassing...
The sub box will be bolted down to the metal frame on the back deck, and that is what will keep everything in place (hopefully)
LinkBack URL
About LinkBacks
