my guess is probably 2 gallonsOriginally Posted by pcmofo
you can do about 2 layers at a time. doesn't matter when you do it, so since you're gonna have to wait for it to dry anyways, may as well put two layers during the first layupOriginally Posted by pcmofo
i'm not sure what you're asking here, can you clarify?Originally Posted by pcmofo
i've had luck wiht 2 layers at a timeOriginally Posted by pcmofo
use foil over the tape, the foil will act as your release agent. try to use wood for any straight panels. fiberglass isn't strong on a flat area, it uses the geometry of the curves to give it more strength. after you have your negative (the part you built to fit your car. dont forget about speaker rings and fleece. to get nicer corners and dimension from that method, i made a 'cage' out of wood dowels and then stretched the fleece over that.Originally Posted by pcmofo
LinkBack URL
About LinkBacks
