Results 1 to 4 of 4
Thread: Help with a custom bezel in ashtray/lighter area *PICS*
    May 2006
    I am trying to modify my ashtray/lighter area to allow me to put a usb hub and a slot load dvd-rom.
    Basically I want to know the easiest way to attach the stock pieces together and fill in the "handle" area on the ashtray then I can modify it from that point.
    It's not made out of ABS so I dont think the acetone trick will work. Maybe it would be easier for me to get a piece of ABS and make my own panel.
    Thoughts?
    Variable Bitrate f1vlad's Avatar
    Feb 2006
    Nashua,NH
    I'd probably do my own panel but I'd probably first give a try to what you got -- make it all one piece fill in between plastic, then cut a hole for CDrom and go from there.
    May 2006
    Quote Originally Posted by f1vlad
    that was the thought, but not sure what to use to fill it in.
    May 2006
    I would glue a peice of abs plastic or wood about 1/8"-1/4" inside the slot and then fill the remaining space with epoxy to flush it up. The expoy will shrink some, so then fill the rest with bondo. Don't fill the whole thing with anything. It will be unnecessarily heavy and more prone to cracking.
  1. Ford Explorer Custom Lilliput Bezel LOOK
    By CDesigns in forum Classified Archive
    Last Post: 05-29-2006, 11:23 AM
  2. Fs: Toyota Matrix Custom 7" Lcd Bezel $150
    By blumatrix03 in forum Classified Archive
    Last Post: 12-05-2005, 09:55 AM
  3. FS - Custom made Car PC Xenarc Bezel for 05+ WRX/STi
    By RR BuGGz in forum Classified Archive
    Last Post: 11-29-2005, 02:13 PM
  4. Xenarc 700TSV / custom e46 bezel mounting
    By zaid175 in forum Fabrication
    Last Post: 06-13-2005, 07:05 AM
  5. Custom Secondary input using old radio bezel?
    By anaxagoras in forum Input Devices
    Last Post: 11-03-2004, 10:54 PM
