Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Fiberglass mixing
    Jun 2006
    Fiberglass mixing
    As everyone knows, when mixing the harner in with the resin, there isn't much worktime..my question is what do you guys usually use to mix it in. I've tried to use glass cups and they will either crack or will just ruin the glass once it hardens. I've also tried platic cups and the resin eats through them. What works the best for you guys?
    Feb 2003
    SE, PA
    I go to 7-11 and grab a few coffee cups. They are paper cups with a waxy coating and hold up fine to the resin.
    G945GLCF2 | 512MB RAM | 160GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | | Xenarc 700TSV |Opus 150W PSU.
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    I use these http://www.cfsnet.co.uk/acatalog/CFS...ng_Cup_93.html
    they can be re-used 6 times or so by cracking the resin out.
    _
    Mar 2004
    Little Elm, Texas
    paint mixing cups at walmart - the plastic ones...
    something like $0.60 a pop.
    as V8 mentioned, they can be reused.
    Jan Bennett
    Dec 2004
    VA
    Styrofoam holds out long enough for 2 uses... I sometime wrap it in tape and get to use it for a day or so.
    Car Mods
    -no car mods
    _
    Mar 2004
    Little Elm, Texas
    I'm not so sure I'd want the styrofoam that's deteroriated to be mixed in to my project....
    Jan Bennett
    Constant Bitrate chuyler1's Avatar
    Feb 2006
    Massachusetts
    I usually use the walmart paint cups as mentioned above. They have ounce marks on the side which is good for mixing. Sometimes I wrap them with aluminum foil if I intend to reuse them.
    2003 Mazda Protege5 -- Clarion/DLS/Eclipse
    Click here for install photos!
    Mar 2006
    Quote Originally Posted by Red GTi VR6
    yes get these.. i used mine for my fiberglass and I just left a 60 cent brush in it.. when the fiberglass was dried I just pulled it out along with the brush and could use it again
    Dec 2004
    VA
    yea the 1x10^-8 m^3 of styro in my resin creates real problems
    Car Mods
    -no car mods
    Jul 2001
    Most commercially available fiberglass resin is polystyrene. That's the same stuff styrofoam is made out of and shouldn't see ill effects if some made its way into the project.
    You mean you guys actually measure out the resin and hardener? Amateurs....
  1. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 04:30 PM
  2. Fiberglass Alternative?
    By FiReToY in forum Fabrication
    Last Post: 04-24-2008, 09:24 AM
  3. 03-05 Honda Accord Fiberglass False Floor...WIP
    By 98EXL in forum Fabrication
    Last Post: 03-20-2006, 09:11 PM
  4. Salvaging my ABS sludge install with fiberglass?
    By evandude in forum Fabrication
    Last Post: 02-11-2006, 07:22 PM
  5. Replacing Dash Piece: Fiberglass or Wood?
    By fatejd in forum Fabrication
    Last Post: 01-17-2006, 12:02 AM
