Results 1 to 10 of 15
Thread: Custom 1.6mm Thick Aluminum Carpc Trunk Case
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    Seeing as I didn't want to buy a pre-made case, I decided to make my own. I bought a 48" x 15" sheet of 1.6mm thick aluminum on eBay for around $20 shipped. I then bought a bending brake on eBay for another $20. Bringing the total to a mere $40.
    Using a Dewalt 18V Jigsaw and BOSCH metal cutting blades, I cut out my sheet into the size I needed. Then bent in in particular places with the bending brake.
    Here is the outcome... so far I have mounted everything solid (mobo, HD and PSU) and made all the openings I need (minus ventelation). The top and sides will be another piece which will screw into two side beams.
    I also realized that my case is the same size as my stock CD changer, so I'll just mount it in the trunk using the little ears on the sides of the case.
    Everything in place, rear of the case.
    Connections.
    PSU mounting.
    Screws holding in the hard drive.
    Side beam, I will make it shorter (in height) for airflow to the fans. The top will screw into it.
    Proposed placement of my 40mm fans.
    You can see more progress pics in my worklog thread here: 1995 Volvo 850 T5 -- 2 din install
    Let me know what you guys think!
    Feb 2005
    Another note.. I'm thinking spraying it with black Plastidip to make it more rugged?
    Constant Bitrate seanshine's Avatar
    May 2004
    Behind the Zion Curtain
    Nice work on those bends there.As far as spraying the case,I'd leave it raw as you'll get better heat dissipation.While I'm looking at it,do you think a
    40 mm fan will move enough air to keep things cool?
    Any sufficiently advanced technology is indistinguishable from magic - Arthur C. Clarke
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Quote Originally Posted by seanshine
    Works in servers. Though they have a few more of them.
    Failure is not an option....
    It's installed by default on every version of Windows.
    Feb 2005
    Quote Originally Posted by BarryWoods
    I'll try two for now, slits on one side and two exhaust fans on the other.
    Feb 2005
    Thanks. Bending the large portions were hard. It maxed out my bending brake.
    Agree with heat dissipation being better without paint.. might just leave it like that. But then might paint it with high-temp flat black ceramic paint.
    Jun 2006
    Quote Originally Posted by LiquidKernel
    One thing I've always wondered if high-temp heats dissipate heat better or insulate the heat better? Based on your statement, I'd assume the former.
    Like I said, always wondered. heh.
    Mar 2006
    thats a preaty cool looking case
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    i would spray it with bedliner paint, but not plastic dip.....i tried doing this to my mound for my LCD once.....its too difficult to get even
    PC Components:
    My work log
    Constant Bitrate damarble's Avatar
    Jan 2006
    Spokane
    Quote Originally Posted by Peoples
    Agreed. I used the Plastidip on a G5 mouse I modified, it was not durable at all and got blisters after a couple weeks. After they popped the stuff peeled off.
    {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
    MY INSTALLATION LOG
  1. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 10:42 PM
  2. Acquiring a custom case?
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 04-01-2002, 12:18 AM
  3. Need A Custom Metal Case?
    By brentp4 in forum General Hardware Discussion
    Last Post: 11-12-2001, 10:19 PM
  4. Making a custom case..............??
    By brandondere in forum General MP3Car Discussion
    Last Post: 01-11-2001, 08:17 AM
  5. digital out on the soundblaster live card and makeing a custom case
    By donalson in forum General Hardware Discussion
    Last Post: 11-27-2000, 06:17 PM
