Page 1 of 9 123456789 LastLast
Results 1 to 10 of 86
Thread: DJiK's Spare Wheel Subwoofer Enclosure Design
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Lightbulb DJiK's Spare Wheel Subwoofer Enclosure Design
    I've been looking to increase trunk space and reduce weight in my 90.
    After 24 hours, I'm done with the design.
    First, the subwoofer (an Audiobahn AW1206T 1,100W RMS):
    Next, its new location in the car:
    ...and how it looks on top of the spare wheel:
    Now, to the design.
    After taking measurment, I mostly used Google's SketchUp to model it in 3D.
    (It was my first time using the program).
    Disclaimer: If anyone says it looks like a toilet bowl, be advised that I'll fishsmack you.
    Anyway, as you can see the "box" is based on two octagons.
    I figured it'd be easier to cut 16 (8x2) walls than try and do an even circle.
    The smaller octagon will be placed inside the rim and the larger octagon would rest on the tire.
    The air volume of the enclosure comes to roughly 1,766 in³ (=1.02 ft³; 28.9L).
    According to WinISD and all given dimensions/measures the sub is tuned to 47.5Hz.
    Please reply with:
    Questions, Comments, and hopefully Insightful Info.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Constant Bitrate damarble's Avatar
    Jan 2006
    Spokane
    Cool idea. I've been wondering how I should mount my sub, because I don't want to lose trunk space either. Your idea might just work.
    Can't wait to hear what you think of the sound once it's built.
    {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
    MY INSTALLATION LOG
    Jan 2006
    considered fiberglass?
    98 V6 Camry XLE
    Status-Everything is working again!
    No progress while I am in NYC
    Ze Worklog
    Apr 2005
    Quote Originally Posted by Anshu
    Yeah, actually xdjxklusivex and I have been talking over its alternatives as you posted this question.
    I don't want to go that route for 3 reasons:
    1. I've never applied fiberglass before.
    2. I want to keep the structure relatively simple -- for dimension purposes.
    3. Nobody is going to see it as it will be a part of the trunk's floor; so I don't need to make extra nice edges and clean corners.
    Quote Originally Posted by damarble
    I'll keep everyone posted about my progress.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you could possibly form the fiberglass around the spare and still retain the spares functionality...unless you need the airspace. i can show you how to work with fiberglass ifyou are interested.
    oh....is it me or does that look like a wooden toilet?
    -edit-
    ah nevermind...damn it. ijust read your entire post and you are retaining the spare with that setup. i say go for it, it'll be a lot cheaper and easier then fiberglass
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Apr 2005
    Quote Originally Posted by scott_fx
    First of all:
    <-- BAD Scott!
    -edit-
    That saved me a reply.
    I guess I should've made this clearer for everyone: The enclosure is going to be sitting on top of the wheel.
    Better yet, I'm thinking of fastening the whole thing down to the same nut that's currently holding the spare in place.
    On another note: Scott, by any chance have you got some leftovers of that sound deadening material you used when you redid your trunk?
    Apr 2005
    I messed up on the volume measurements.
    This is closer to reality.
    I'm getting 47.5 Hz in WinISD with the new measurements now.
    Sep 2005
    Funny
    You start with inches even have some measurements up to 9 digits after decimal
    And end up with a volume in liters
    Would that not be easier to start rightaway decimal
    Habits stay as long as we are living !!
    Jul 2001
    I hope you're really good with a tablesaw. Otherwise those angles will drive you crazy. I wish my spare tire well was that huge.
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    for me to poop in!
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
  1. Replies: 28
    Last Post: 01-17-2006, 07:58 AM
  2. Car PC in spare wheel well a good idea?
    By Telos in forum General MP3Car Discussion
    Last Post: 04-28-2005, 02:29 AM
  3. subwoofer enclosure design software?
    By urafreak in forum Car Audio
    Last Post: 03-18-2005, 06:00 PM
  4. How to secure a subwoofer enclosure?
    By SwapMeet in forum Car Audio
    Last Post: 02-15-2005, 08:31 AM
  5. Spare wheel well project (In works)
    By [iG] in forum Fabrication
    Last Post: 06-24-2004, 10:45 AM
