Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
Thread: Miata In-Dash Fabrication
    Low Bitrate keyvan's Avatar
    Dec 2005
    Orange County, CA
    Hey. You can see my old setup at the link in my sig. Today I decided to start actually making it look stock. Took out some bondo and slapped it on.
    Right now I am a bit stuck with some little holes and also I ahve the dillema of SANDING THE CORNERS. I dont know what to do. Some kind of ball-shaped dremel head perhaps? I dont know how to do a good job sanding this.
    Any tips would help.
    Check it out so far at this link
    http://www.aescarpc.com/dashfab/
    1997 Mazda Miata, Black
    MiataPC
    In-dash Fabrication
    Current dashboard: http://www.aescarpc.com/miatapc/2
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    your first mistake was not taking enough care when you put the filler on. You need to put it on a lot smoother than that, when you do it gives you a lot less work sanding it and a lot less pin holes. Start sanding with a coarse grade paper get the shape you want then go finer to fill the scratches. Using something like the dremel will take the sweat out of it but will leave you with a very uneven wave like surface. For the corners again if you put it on carefully it will give you a lot less work as you can form the radius when the filler is soft to anything you want. Only way to do it now is work out what radius you want and find something the same, dowel pencil whatever and wrap it in sandpaper. If you want a sharp edge use course paper folded and sand with the edge.
    What you have actually needs another layer of filler on it as spotting is only good for very shallow fills or pin holes, it isnt strong enough for general filling. Keep at it as it will be worth it in the end and its all your work.
    Dec 2005
    Orange County, CA
    Thanks,
    What do you mean by another layer of filler? Just slap another layer on there? is it so i can form it better or is it because you think it would need more structural support?
    Yeah, my first bondo job so i had no idea when i slapped that first bit on.
    Also, if you notice on that first one where it really came out ****ty, i was actually trying to fill the edge with filler instead of using a peice of cardboard or something to make an actual wall. I thought this stuff would be like play doe. But I learned on the other edge which came out real nice.
    MiataPC
    In-dash Fabrication
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by v8 scimitar
    Using something like this:
    Black & Decker Cyclone 4-in-1 Multi Sander
    ...should allow you to sand much more quickly than by hand, and without the suface gouging that results from dremeling. It has a flat bottom, and multiple speeds. $50 is a bit expensive, but I'm sure you could find one used or off brand for much less. Well worth it in my experience and opinion.
    EDIT
    Apparently that link doesn't work well...just go to the home depot and search for the product name if you're interested.
    Feb 2006
    Schaumburg, IL
    you all do understand that bondo has no structural properties right?
    Its just a filler made to smooth out bumpy surfaces. It will crack in a short amount of time
    I rarely use filler in my projects and when i do, its just to cover the luquid plastic layer to get it as smooth as possible.
    this is just an FYI, id hate to see your project fall apart
    2003 Ford F-250 7.3L Diesel Crew Cab
    Pictures of my truck, hobbies, and more HERE
    Mar 2006
    Go to walmart.. they have a $10 electric sander.. plugs into an outlet and it is amazing.. i was working with sanding blocks and they weren't doing me any good. Got the electric sander and it worked flawlessly. Well worth the investment and will work just like any black and decker product.
    Dec 2005
    Orange County, CA
    sciontC:
    The bezel is attached very well with alot of epoxy. Is that enough for it? There wont be any particular stress on the bondo itself, unless it will crack from heating and cooling, or being in direct sunlight. Think I should be worried?
    MiataPC
    In-dash Fabrication
    Jul 2001
    keyvan, looks like you were a little on the skimpy side with the hardener. You might have problems with heating/cooling expansion and contraction.
    Apr 2006
    hey keyvan,
    how do u like the exaudio touchscreen?
    Dec 2005
    Orange County, CA
    it gave me hell earlier when i first got it. peice of junk. i maen its a lilliput but damn the build quality was **** on my particular one. I have 2 dead pixels first of all, and the ffc cable and connectors weer all broken. I had to jimmy rig a solution for it.
    terrible, there are alot better screens out there now for even cheaper than the ex-audio (it's 215 dollars shipped at the moment)
    MiataPC
    In-dash Fabrication
  1. Starting in dash fabrication
    By Cris in forum Fabrication
    Last Post: 08-23-2008, 03:54 PM
  2. Duramix is the Answer for Dash Fabrication!
    By johnram in forum Fabrication
    Last Post: 01-16-2008, 08:42 AM
  3. Replies: 15
    Last Post: 09-22-2005, 09:31 AM
  4. Dash Fabrication for Chevy Truck!
    By voidunknown in forum Fabrication
    Last Post: 04-06-2005, 08:31 PM
  5. 2003 Altima Dash Fabrication
    By in4no in forum Fabrication
    Last Post: 02-11-2005, 11:51 AM
