What should I do?
I wish I could show a picture, but my description should be enough. My first attempt at fiberglass was fiberglassing my lilliput frame to my radio trim... I admit I did a pretty ****ty job the first couple layers of fiberglass, which probably messed me up. I sanded a good portion of it down though, so it wasn't that bad. I have been using an electric sander, so the spots aren't that bad, but I still have tiny holes (i'm assuming from air bubbles) in my work. I just looked a thread and he was going to use the spot putty to fix in the holes, is that what I need to do? I was either thinking just applying resin or bondo or I guess spot putty. Thanks for any help.
CLIFF NOTES
1) I have tiny air bubble holes in my bezel
2) What is the best way to fix this
3) Thanks!
yup bondo or spot putty is the way to go. Spray filler wont even work very well as it will still leave some holes behind.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
