Results 11 to 20 of 27
Thread: 6" linear movement
  1. #11
    Oct 2004
    NY
    I've done a few motorization jobs with those aftermarket power window lift kits.... the kind that are cable operated & mount the motor remotely.... they can do some awsome things... may be a bit overkill for your app though...
    I like to use either those, or salvaged sunroof motors that also work with cables.... even a smaller motor with cable operation could do... cables are nice because you can move the motor away to where you have space for it, & by being overkill insures a lifetime of trouble free usage...
  2. #12
    Jul 2001
    I forgot to mention that you can use a windshield wiper motor with threaded rod from Home Depot.
  3. #13
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    these are great ideas guys. i'm looking into them all. if the price gets within $30 of the linear actuator though I'll probably just get one of them due to the ease of installation and reliability.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  4. #14
    Oct 2004
    NY
    one car i did, I had a screen pop up out of the dash.... I used the motor from a me/be folding mirror assy... the motor is made by bosch....
    I like to recycle car components because you know they are made for a very high cycle life....
  5. #15
    Dec 2004
    Los Angeles Ca
    i was over at www.motioncontrol.com and got the idea of using a flatbed scanner assembly. it has the rails and everything. just anohter idea
    M10k
    My Car Pc Install
    My Boat Pc worklog
  6. #16
    Constant Bitrate damarble's Avatar
    Jan 2006
    Spokane
    Here's a simple idea. Have a line hooked to one end of your panel, the other hooked to a spool on a small motor. When the motor spins it winds up the line and pulls open/close the panel. A spring or another motor/line will be on the oher end of the panel for return. A pulley system can be used to save space if there isnt enough room to either side of the panel.
    Excuse my quick and dirty paint drawing, but I think it gets the point across.
    {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
    MY INSTALLATION LOG
  7. #17
    Dec 2004
    Los Angeles Ca
    thats another good idea too.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  8. #18
    Oct 2004
    NY
    the difference between that & the cable operated I said is that the motor would reverse & "push/pull" it either way...
    if you do one direction with a spring you'll need a way to hold it open.... when the power goes away from the motor the spring will pull it closed... you could use a locking latch & have it release to close it... then the spring might snap it to fast... you'll have to dampen it too...
  9. #19
    Dec 2004
    Los Angeles Ca
    i picked up a usb scanner off ebay and i'm going to use the internal mechanism to slide the panel back and forth. I figure the power requirements will be optimal (5v since the scanner is usb powered) and the track, motor and belt are already fabricated for me. I'll know better when i get the thing taken apart.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  10. #20
    FLAC evandude's Avatar
    Mar 2005
    Maine
    I think the scanner is probably a decent plan. having the rails and slides already makes life easy. The belt mechanism in a scanner is probably one of the best solutions, very efficient and fast in both directions. The main down side i would think would be that the belt and rails would have to run the length of the travel area (thus might be showing when the panel opens, depending on how you mount everything), whereas with rails and a lead screw you could potentially have the whole mechanism hidden behind the panel and in the compartment it slides into... but obviously it all depends on the application.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
  1. Linear Actuator?
    By kickercivic1 in forum Off Topic
    Last Post: 11-30-2007, 03:47 PM
  2. spal linear actuators/wiring question
    By plymouth37 in forum General Hardware Discussion
    Last Post: 05-28-2006, 06:20 PM
  3. Mouse movement Command
    By DiNASTY in forum RR Skins
    Last Post: 02-15-2006, 10:55 PM
  4. RAM movement causing problems!! Need Ideas!!!
    By techy101 in forum General Hardware Discussion
    Last Post: 11-25-2005, 12:11 AM
  5. Who knows something about linear actuators?
    By SuperMatty in forum Off Topic
    Last Post: 05-06-2003, 04:22 PM
