dimensions?
Dear all car pc owners. Im on the way of fabricating a new casing.
Material : Aluminim
Price Range USD 50 - 60 ( may reduce )
Warranty : 1 year
Delivery: Anywhere around the world. Minimum charges.
Order Info: No minimum quantity.
For Resellers : Minimum 10 pcs per order
Will keep you all posted.
Will look something like this...
dimensions?
If it holds an Intel Board I'm very interested. Lighted too?
John
Looks like an alpine PDX amp.
http://www.alpine-usa.com/en/product...odel=PDX-2.150
2007 Tahoe
Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
My Install
Well the design is almost similar. I try to make it easy and user friendly. Less screws. Easy to open and well ventilated. Unlike what you get in other casings like travla . My god....Just to chance the psu i need to open almost 12 screws and i need a philip screwdriver and a alan key...Originally Posted by Naamanf
Originally Posted by Kalt
180 x 56 x 254.0 mm ( W x H x D )
Comes with 1 vent 40mm fan. And may b 2 usb ports. Im considering about the lights. Cause i need to test first. Will keep you guys posted..
Not to sure whats your board dimension...May put in lights.Originally Posted by TMF
hey, I have a couple of suggestions, some you might like, others not!
Rather than having the sides meshed up, it would be better to do something like this:
Two fans can then be used in the open space and this would have much better cooling than an open design. The mesh side can have some foam to limit dust.Code:Solid +----------------+ M | | - Solid e | | - OPEN s | | - OPEN h | | - Solid +----------------+ Solid
You could use, or allow the use of quick release thumb screws, for easy maintainance.
and finally, have the holes ready to use any of the current PSU's (could be a deciding factor in case buying).
Current:
[BMW E46 ///M3 Convertible]
Previous:
[BMW E31 850CSi]|[BMW E39 535i]|[BMW HVAC Research]|[IBUS Scrolling Text]|[BMPuter]|[Velocity]|[TomTom]|[Vision]|[Space Navigator Driver]|[Super Fast Boot]
looks neat.. can it hold a slimline optical drive?
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
Not sure... It's whatever is listed here in the store for the Celeron 2.0GHz mobo. I've already ordered the system here but am always interested in something that makes the trunk look better. I am having those new Alpine amps put in and that's what caught my eye on your case.Originally Posted by virginblue
When you get an actual prototype assembled, please post pics!
John
