Results 1 to 5 of 5
Thread: RSX Dash - First Attempt
    Registered User InHoc's Avatar
    Feb 2006
    Alabama
    RSX Bezel - First Attempt
    I've been working on this project for awhile, and this was my first shot at fabrication. I read a lot about the ABS sludge method, and attempted to use this PC-7 stuff to fill in cracks. (let me back up -- the faceplate of my xenarc was epoxyed to the dremeled bezel.) I then used the PC-7 to fill in the cracks and make the piece solid. Unfortunately, I forgot to take picture until the first coat of primer was already on.
    Here is the first coat of primer I sprayed. I wanted to see where my divots and imperfections were...
    Here is a picture of the PC-7 stuff..
    Here is the bezel with a much better sand job, and some touch-up
    Test fit in the dash...
    Backside of the entire piece
    And the piece after a few coats of paint...
    The piece could use a little work on the inside corners, but for now, I'm happy. I'm pretty anxious to get the system installed, so more work on the bezel will have to come later.
    As for the PC-7, I'm very happy. The piece is very sturdy, and the PC-7 molded very easily. The solution is pretty thick, so you can really put it where you want it without it running. The sanding was surprisingly easy. All total, the piece probably took about 2 total hours to complete.
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    looks great, from the pictures i cant see any defects at all!!! not to say they arent there, i just cant see them!
    seriously tho, great job, looks very stock.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    actually, if its a minor flaw your eye will be drawn to it immediatly even though someone else might not see it. it looks pretty damn good. nice job.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
    not bad... but id reconsider not finishing off the screen PERFECTLY.. you see it every time you drive teh car, and it has to withstand lots of abuse. that was at least the most important thing when doing mine. i used a sanding block and actually recessed the screen into the dash a bit. it turns out the bose stereo faceplate has a nice cutout thats perfect for the screen. i think my rsx pictures are still up on here if you want to have a look.
    i used a paint "trim black" from pep boys.. that gave me that perfect OEM finish as the side panel where the sunroof buttons are. they match almost exactly. some people think the screen is stock =P i just say yes, and go on my way.
    Carputer HIFI car stereo project!
    [XXXXXXXXXXXXXXXXXXXXX-]
    95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
    [XXXXXX--------------]
    30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
    Feb 2006
    Alabama
    I know exeactly what you mean. It's like that dead pixel that "nobody can see," but it seems to grab your eye everytime you look.
  1. 2003 BMW M3 Custom Dash / Overhead Console
    By gork in forum Show off your project
    Last Post: 01-01-2008, 08:52 PM
  2. Help on custom dash for Caddy STS
    By Slaughterhouse in forum Fabrication
    Last Post: 12-14-2006, 07:47 PM
  3. 2000 Honda Civic Dash LCD intigration
    By pcmofo in forum Fabrication
    Last Post: 03-20-2006, 12:09 AM
  4. First attempt at F150 custom dash
    By crazyone in forum Show off your project
    Last Post: 03-08-2006, 10:57 PM
  5. 01 Dakota Dash
    By jpx7777 in forum Fabrication
    Last Post: 02-19-2006, 10:19 PM
