Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: carbon fiber sub box
  1. #11
    Jul 2006
    Actually, the glass idea came from NASA for surface finish. they got tired of repolishing flat aluminum tooling because of nicks, etc.
  2. #12
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Quote Originally Posted by Red GTi VR6
    you can get a flat surface from it.
    You don't lay glass on the top, you use duraglass on the bottom for structural support, bondo the top to get the smooth surface, then lay your carbon fiber over that.
    I think he meant a piece of window glass to make it smooth. Not fiber glass. As for putting the glass on top, it will probably do the same thing as the Al. The epoxy in the carbon will flow down to the plywood. Unless you cook the stuff upside down. I don't think there's enough there to give it the clear glossy look you're looking for.
    Failure is not an option....
    It's installed by default on every version of Windows.
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by stkdidy ntshidy
    i scrapped the idea of doing a fiberglass buildup after realizing in a sample piece that i would never get a flat surface out of it.
    I was basing my response on this comment. Thinking the OP was trying to get some shape out of the enclosure rather than just a flat sided enclosure.
    As such, my response.
    Jan Bennett
  4. #14
    Low Bitrate stkdidy ntshidy's Avatar
    Jul 2003
    california
    i've got a number of pics of my progress so far, but my home internet (at work right now) doesn't work atm. i will get those pics up as soon as i can.
    2005 Mustang GT:
    12w7...arc audio kar1000.2t...jl 300/4 pushng focal 165k2p...pioneer premier deh-880prs...tm-701l...audiocontrol eqs
    want: my stereo actually IN the car
  5. #15
    _
    Mar 2004
    Little Elm, Texas
    sweet!
    can't wait to see them!
    Jan Bennett
  6. #16
    Jul 2003
    california
    basic box assembly has begun. i only have the right side panel fibered at the moment, but it is glued to the assembly which includes the floorboard, middle support (left wall of sub enclosure), right carbon wall, and top board.
    i was recommended by Tap's Plastics (very knowledgeable shop) to get some clearcoat epoxy for covering the fiber because it wont turn yellow, and wet sands extremely glossy
    2005 Mustang GT:
  7. #17
    _
    Mar 2004
    Little Elm, Texas
    that's only if it's UV protectant epoxy. There is a difference, and yes, if you don't have it, it will turn a nasty yellow...unfortunately...
    Get some 600 grit, then 1500 grit, then 2000 grit paper, designed for wet sanding, as well as a block for wet sanding, and set up a bunch of towels in the living room on the floor in front of the TV and pop in a really good epic and have fun....lol
    Jan Bennett
  8. #18
    Jul 2003
    california
    ya they made sure to tell me UV protective, or else it would yellow in 1-3 months.
    i was thinking 400grit, 800grit, then buff with one of those power car-detailing-polisher units and some car polish...but i def know what you mean as far as time involvement
    2005 Mustang GT:
  9. #19
    _
    Mar 2004
    Little Elm, Texas
    if you're going to use one of those units, make sure it's a random orbit, not the cheap $30 unit you get at walmart or sears. The porter cable random orbit is considerd by many to be the best for detailing cars on the amature level.
    Else you will end up with nasty swirl marks.
    The car polish works well, I used it on mine. just start with a light grit, then go heavy, then back to light, being sure to use a dedicated pad for each grit.
    Jan Bennett
  10. #20
    Jul 2003
    california
    i got a bunch more progress done, and am doing more today. i have about 10 pics of what ive done so far. ill post them up when one of the panels (cf) is done cookin so i can pose it in there too
    2005 Mustang GT:
  1. Can't find Carbon Fiber or Kevlar Tutorials...
    By rbarr110 in forum Fabrication
    Last Post: 07-09-2006, 09:57 AM
  2. Working with carbon fiber
    By HHdesign in forum Fabrication
    Last Post: 08-28-2005, 01:27 AM
  3. Carbon fiber overlay?
    By SM-4 in forum Fabrication
    Last Post: 10-03-2004, 11:05 AM
  4. carbon fiber
    By djXternal in forum Fabrication
    Last Post: 07-07-2004, 05:55 PM
  5. Buying fiberglassing and carbon fiber products..
    By TintedChrome in forum General MP3Car Discussion
    Last Post: 01-15-2003, 02:56 AM
