Results 1 to 8 of 8
Thread: 2002 Silverado Custom Dash Bezel
    Newbie AZ_Silverado's Avatar
    Jun 2006
    Peoria, AZ
    Decided I wanted to do some work on the interiror of my truck, and this has been a pretty easy fabrication so far.
    I started by taping off around the deck:
    Trimmed off the excess:
    Dash bezel back in place:
    I used duramix 4040 (which is a semi-rigid plastic repair) to tack the deck bezel to the dash bezel:
    I'm in arizona, so it only took a couple minutes for that stuff to set; then I removed the dash bezel:
    Masked off the front side of the bezel so I could come from the back and fill in the gaps with more Duramix. If I could do it over I wouldn't have taped all the way to the bottom of the dash bezel, but to the middle part that separates the din from the a/c controls:
    Here is a shot of the back side after I applied the Duramix in the gaps. I taped the inside of the deck bezel that way I wouldn't get any Duramix in there to save time on sanding later:
    Shot of the front side after sanding with some 50-grit. I also filled in that space on the left side of the dash bezel the same way as well as filling in the gap that goes around the outside edge.
    Body filler applied. I use Evercoast Rage Gold, which is a lightweight filler. It spreads and sands much easier than the Bondo and is pretty much the same price. Working in 100 degree weather made it kinda tuff to get the filler/hardner ratio right though. The first couple tries I only had a minute or two working time with it:
    Sanded with 50, 60, then 80-grit:
    Jun 2006
    Peoria, AZ
    Some shots after a couple coats of primer. I wanted to get a better visual of the imperfections and there's quite a few. I was hoping that since I was using a high-build primer it would fill in the texture on the bezel, but it didn't. I'm using an HVLP gun and I'm pretty inexperienced with it so maybe I'm doing something wrong. I'm gonna fill in a couple pin holes and go over the whole bezel with some metal glaze, then prime it again, and attempt to paint it myself. I've already got the paint to match the color-code of my truck:
    Well that's it for now. Let me know what you guys think.
    Constant Bitrate blacklancer's Avatar
    Nov 2005
    Los Angeles, Ca
    lookin good so far. can't wait to see it all finished and painted.
    _
    Mar 2004
    Little Elm, Texas
    looks nice!
    Jan Bennett
    Das
    Das is offline
    Constant Bitrate Das's Avatar
    Aug 2004
    Texas
    Is that textured? If so what did you use to texture it?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    looks nice, any plans for the blank area above the radio? oh..and uhm...what happened to your ac controls?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jun 2006
    Peoria, AZ
    Quote Originally Posted by Das View Post
    Its just the stock texture of the bezel. I just primered over it.
    Jun 2006
    Peoria, AZ
    Quote Originally Posted by scott_fx View Post
    No plans right now. Eventually I want to put like a 7" LCD in that spot. Don't have to cash for that right now tho. The a/c controls will still be in the same spot under the deck. I didn't fabricate them into the bezel.
  1. 2003 BMW M3 Custom Dash / Overhead Console
    By gork in forum Show off your project
    Last Post: 01-01-2008, 08:52 PM
  2. Post Your Custom Dash Pics Here
    By EsKALad in forum Off Topic
    Last Post: 02-10-2006, 01:05 AM
  3. custom dash?
    By Jamez_Warner in forum General Hardware Discussion
    Last Post: 06-14-2003, 06:53 PM
  4. custom dash making....
    By ifnh573 in forum General MP3Car Discussion
    Last Post: 10-13-2001, 01:39 AM
  5. Plastic moldings for custom dash
    By mykolJay in forum General Hardware Discussion
    Last Post: 06-26-2000, 01:06 AM
