Results 1 to 10 of 10
Thread: Mounting Suggestions?
    May 2006
    Question Mounting Suggestions?
    First of all, this is a carputer on the cheap. I got the PC free from work. It's a Gateway Profile 3 all-in-one PC, pretty much a 15" FPD with drives, MB, etc mounted on the back. I've did some measurements and found out with a little bit of modding, the whole thing fits somewhat nicely.
    Here's a pic of the open space
    Ideally, this is the position of the computer when I'm not using it.
    And I would like the whole thing to slide up and out to this position.
    For reference, here's the back of the machine.
    The machine typically sits on a stand and has about 30° of motion. I've looked at standard VESA mounts for monitors, but most seem to large to work well.
    Any ideas?
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Your comment concerning the size of the VESA mounts makes me think you're looking for a bolt-in/zero mod solution...which I doubt exists.
    I noticed this is your first post...although you've been a member for a few months...do you have experience with this sort of thing/carpcs in general?
    May 2006
    Quote Originally Posted by parksgm View Post
    I'm not really looking for a zero-mod solution, because I really doubt one exists, I'm just looking for suggestions on a good place to start, ie using mounts from a slide-out keyboard from a desk, etc.
    This will be my first carPC, its kinda a test run I guess, since the car I'm putting it in isn't really that great, (as is the PC going into it). I'm just trying it out to see what functionality I would really like in a carPC. Once I get a decent enough vehicle, then I'll have a little bit more experience with the install/use of a carPC.
    Constant Bitrate Friedrice's Avatar
    Jul 2006
    Thailand
    A good point of ref might be looking how a car trunk opens up. Imagine the top of the trunk being your carputer in the "unused" position and try to mod from there. maybe a slide out railing then the cartrunk mechanism type hardware will push the screen to your desired position. Or you can go the way of some actuators, step motors or servo. Check out some other posts through search. Lots of ideas you can start with and mod as needed.
    Rep! Rep! My kingdom for some rep!
    My WIP
    Ghetto Carlaputer: (putting things together) 0% * * * * * * * */2 - - 100%
    Wife's patience: 0% * * * */2 - - - - - 100%
    Newbie ~Rob's Avatar
    Apr 2006
    UK
    If it was me, I'd put the PC in the trunk and run a VGA + USB cable to a touchscreen up front somewhere reachable. Where you propose to put it will make it a nightmare to use with a mouse, especially if you're on the motorway
    Maximum Bitrate DeltaFX's Avatar
    France
    Rob, watch carefully : No VGA output.
    if it was me, I'd first open the beast.
    Now Galileo is real. Muhahahahaha :p
    Apr 2006
    UK
    Quote Originally Posted by DeltaFX View Post
    oops! Who's bright idea was it to colour the serial port blue? I bet there's a VGA header of sorts on the mobo though!
    Jul 2001
    and I bet that monitor's plugged into it.
    May 2006
    Quote Originally Posted by Friedrice View Post
    Interesting,I didn't think about using pneumatic pistons. I'll have to take a look at that. Thanks for the suggestion.
    Quote Originally Posted by ~Rob View Post
    While I haven't ripped too much into the thing, I'm pretty sure the LCD is hardwired to the mobo, similar to most laptops.
    Aug 2006
    I already opened one of those.
    1st, No PCI expansion or AGP slot and YES, the LCD is hardwired to the mobo.
    If you try to fiberglass it, you'll reallise that everything was holding on the facade and the CD drive was on the side. In other words, It's not really "builders friendly".
    Second, You will never be able to run this PC on something else than its own screen. Useless if you plan to add Headrest or Trunk LCD in the future.
    Personnaly, I would go with flat recycled Desktop PC (Ex: Dell GX240, Compact etc) in the trunk with a TS Monitor. Since you already have the CPU, HDD and Memory, only buying the used Case and a mobo would be cheap. (under 50$)
    Having a Touchscreen monitor, will make it stronger because of the thick glass over it. It's nothing to compared to the breakable, scratchable, low angle vision All-in-one PC screen you own.
    My 2 cents
  1. looking for lcd mounting suggestions
    By wiper in forum LCD/Display
    Last Post: 12-11-2005, 04:53 PM
  2. Mounting a 700tsv
    By ninjatill in forum LCD/Display
    Last Post: 10-07-2005, 12:47 PM
  3. Mounting my carputer on a board - How about some suggestions?
    By PDiddy in forum General Hardware Discussion
    Last Post: 10-05-2005, 07:01 PM
  4. LCD mounting suggestions
    By electron in forum Newbie
    Last Post: 12-14-2004, 01:59 PM
  5. LCD mounting suggestions
    By Shrynn in forum General Hardware Discussion
    Last Post: 10-15-2004, 12:31 PM
