why not give it a go yourself?
also, why not try local shops?
I need a alpine 6.5" touch screen installed in my center console of my 92 merc 400e where the radio currently resides. I only want the screen to be shown with no bezel like most people have done here. I can send the center console/screen to if someone is not in the detroit area.
Jan Bennett
probably going to be costly seeing as it is a custom job.
1.9in x 2.9in -- 47mm x 73mm
i checked local shops and they wanted 650.00. I don't have a garage to work in currently since I just moved here and I honestly don't have the time.
very well then.
You might also consider hitting up some dedicated car audio forums.
Since it's an alpine piece, there's a good deal more risk involved since those are typically more expensive than a VGA monitor like we all use here.
Jan Bennett
any suggestions as far as a good car audio forum
www.caraudioforum.com
for starters...
google for others, there's quite a few of them out there.
however, someone here just might be willing to help you out so keep checking your thread.
Jan Bennett
I tried that forum with no luck. seems more people are fabricating on this forum. I'll keep checking this thread.
I checked sound domain and no luck there either.
