Page 11 of 11 FirstFirst ... 234567891011
Results 101 to 107 of 107
Thread: Working with Foam
  1. #101
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    I needed to make this:
    Which will fit snugly inside the double din hole in my dash which the screen will sit flush up behind. I had no luck finding suitable foam, but based on what I've read in this thread, I made it out of balsa wood. Easy to shape and get super smooth (by using model dope, mixed with talcum powder and painting it on) and now I've got to where I'm happy with it.
    My silicone, casting resin, resin pigment all arrived in the mail the other day, so I'll be ready to do it this weekend hopefully, using the methods described by GoHybrid.
    I'll post pictures when I'm done...
    I installed my carpc into my pet Kangaroo, mate.
  2. #102
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Foam is sweet stuff. I have TONS of this stuff at my shop in 15 and 18 lb density. Its known as HDU or High Density Urethane in my business. Never even thought of using this stuff for a bezel but after thinking about it, this would work well. Not for structure though, just as trim. When you go thin it gets brittle and will crack if enough pressure is applied to it. But for trim work its almost a perfect solution, Great Idea man!!
  3. #103
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    yeah, i think whenever i can afford to make a mold from a foam plug and cast in plastic i would, but the foam itself is so cheap and easy to work into several iterations to decide what you want to do.
  4. #104
    Jul 2005
    Motorcity
    Blog Entries
    1
    well your corolla bezel looks great man! I mean really professional. How did you hook up your mini to the eclipse? Great work I may try this out just cause I have foam laying around, I lucked out because my car has a DD aftermarket trim kit mass produced.
  5. #105
    Jun 2006
    Denver, CO
    the mini is connected to the eclipse through the little $30 DVI->NTSC adapter that Apple sells, and then the sound goes through the auxiliary input. The picture isn't the sharpest it could be, but since Front Row was designed to be viewed on a TV, it doesn't look any worse for it. I had to ground the parking brake sensing wire from the eclipse though to keep the video inputs on while moving.
  6. #106
    Mar 2006
    Colorado, but Canadian!
    Bump for awesome fabricator, and also for a great method to making bezels.
    I vote to make this a sticky!
    1.9in x 2.9in -- 47mm x 73mm
  7. #107
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by 2k1Toaster View Post
    I second that motion. I remember reading this a couple of months ago and being impressed, and here I am impressed all over again (and closer to attempting a bezel of my own).
  1. Yard Sale
    By agashka in forum Classified Archive
    Last Post: 08-21-2006, 11:41 PM
  2. Liquid Foam
    By JPuma in forum Fabrication
    Last Post: 08-31-2005, 09:59 PM
  3. Foam
    By bmwperson in forum Fabrication
    Last Post: 09-15-2004, 05:35 PM
  4. Before you use foam to mount your Touch Screen
    By NewTechFool in forum LCD/Display
    Last Post: 03-05-2004, 02:33 PM
  5. Fiberglass over foam?
    By gork in forum General MP3Car Discussion
    Last Post: 08-20-2003, 06:57 AM
