Page 7 of 11 FirstFirst 1234567891011 LastLast
Results 61 to 70 of 107
Thread: Working with Foam
  1. #61
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    i'm excited to see a thin-wall casting! Do you have any thoughts on which resin system you might use to make the final part?
  2. #62
    Feb 2004
    I've done this before...
    Last time I did this, I used Polytek's Poly15 series of resins:
    http://www.polytek.com/products/poly15.html
    Read up on the two threads I started nearly 2 years ago:
    How to: Duplicating a radio bezel.
    8.4" LCD in WRX dash.
    They're long dead threads, so don't add anything to them, but they're still interesting reading.
    The problem I ran into during the mold making was that the container wasn't rigid enough.. I used 1/2" thick posterboard, which was too flexable for the size of work required.. MDF is much better.
    Back then, I didn't have a tablesaw to cut MDF, and I didn't have a X2 mini mill.
    I got this model from MicroMark:
    http://www.ares-server.com/Ares/Ares...oduct&ID=82573
    It's the same as this one from Harbor Freight:
    http://www.harborfreight.com/cpi/cta...emnumber=44991
    Now I have a table saw, and a mini mill, and hope to convert the mill to CNC within the next few months, with this much larger table:
    http://cncbridges.com/mmb85265.htm
    They're coming out with a slightly larger table soon that can cover a full 26"X by 12"Y of travel, more than enough to mill anything I want - including complicated radio bezels.
    Anyway, getting off topic there..
    My current plan is to buy a replacement lower center console (the area where the radio is mounted) and a replacement radio bezel - both available for less than $50 each - and to carve / mill blocks of foam to fit.
    This lets me work on the project without having to have my dash torn apart.. :-)
  3. #63
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    Quote Originally Posted by GoHybrid View Post
    well go to smoothcast.com
    to check out what thet have, i really recommend ordeting from www.farwestmaterials.com
    this is their phone number, if they are still in business last time i worked with them were 5 months ago
    (509) 522-0556
    they have a great support, look at smoothcast 300 it's a 50/50 compound resin sets with in 10-12 minures, very durable, if you want smoother rubber like finish, i highly recommend dragon skin, i believe you can get a quart trial kit for about $15 USD.
    I am a professional scale modeler, and have been casting, molding, and sculpting & painting miniatures for over 5 years
    I hope they are still in business, plastics has been tough business laterly
    Yev
    R. T. F. M
  4. #64
    Feb 2004
    Quote Originally Posted by Yevmeister View Post
    I think you meant www.smooth-on.com - smoothcast.com doesn't resolve.
  5. #65
    Nov 2005
    Chicago
    yeah sorry i haven't been in this business since i got my car
    yev
    R. T. F. M
  6. #66
    Nov 2005
    Chicago
    Dakar m3
    if you don't want to drop too much money into quality stuff i suggest starting with florist foam, it's cheap, and very easy to shape, you can get it in any craft store
    here is some pics from fiberglassforums
    sorry little off topic, but this might work for the budget
    Yev
    R. T. F. M
  7. #67
    Constant Bitrate blacklancer's Avatar
    Nov 2005
    Los Angeles, Ca
    can you fiberglass right over the floral foam??
  8. #68
    Jun 2006
    Denver, CO
    I think the resin (unless you were using an epoxy) would chew it up to some degree. If you're going to spend a month sanding the fiberglass and fillers and hack out the foam later, then no big deal, but if you're trying to make a mold and keep it accurate, I'd look at a different kind of foam or resin.
  9. #69
    Nov 2005
    Chicago
    Quote Originally Posted by blacklancer View Post
    yes you can
    R. T. F. M
  10. #70
    Nov 2005
    Chicago
    floral foam is heat resistant, and even with slight chew ups, they can be easily fixed with evercoat body fillers.
    make a mold from the final product after you are done.
    the reason that solution caught my eye is because of the price you can get a case of 60 9 x 6 x 3 blocks for under 40 usd. and it's a good practice before you get to work with expensive stuff, my philosophy is, basic bondo fillers are crap, i learnt hard way but i got good experience is sanding, before i went with better evercoat products.
    I would recommend floral foam to any first timer, then you can get to the professional equipment which is pricier, but get's you better results, as Hybrid pointed out
    He is professional in what he does though
    Yev
    R. T. F. M
  1. Yard Sale
    By agashka in forum Classified Archive
    Last Post: 08-21-2006, 11:41 PM
  2. Liquid Foam
    By JPuma in forum Fabrication
    Last Post: 08-31-2005, 09:59 PM
  3. Foam
    By bmwperson in forum Fabrication
    Last Post: 09-15-2004, 05:35 PM
  4. Before you use foam to mount your Touch Screen
    By NewTechFool in forum LCD/Display
    Last Post: 03-05-2004, 02:33 PM
  5. Fiberglass over foam?
    By gork in forum General MP3Car Discussion
    Last Post: 08-20-2003, 06:57 AM
