Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 61
Thread: Fiberglassing Gauge Pod in Bezel *pics*
  1. #41
    AMP Creator aychamo's Avatar
    Jun 2006
    Quote Originally Posted by red_parchel View Post
    THATS GENIOUS!
    I think that incorrect spelling is the most ironic thing.. ever!
  2. #42
    _
    Mar 2004
    Little Elm, Texas
    ummm...I can't tell if you're being sarcastic Peoples or not....about the wrap....
    Jan Bennett
  3. #43
    Jun 2006
    It just needs heavy sanding afterwards.
  4. #44
    Variable Bitrate wallaceacura's Avatar
    May 2005
    SE Wisconsin
    Quote Originally Posted by Peoples View Post
    I personally like the fiberglass jelly they sell at walmart. Its very easy to work with......but when you get to the sanding part, its like sanding a rock
    Got a link for this? I just tried a search at walmart.com and didn't come up with anything.
    Biostar M7NCG 400 ver 7.2 AMD Mobile Athlon 1.1GHz (@ 1GHz), Kingston PC2700 512mb WD 80gig HD Custom Case Opus 150W PS Lilliput 7" TS D-Link DBT-120 BT D-Link DWL-G122 WiFi Holux GR-231 GPS nLited XP Pro iGuidance RoadRunner frontend
  5. #45
    Variable Bitrate red_parchel's Avatar
    Jul 2006
    Boston, Ma
    [ot]
    requests vbulletin to support automatic spell checker/un-idiot-a-tizer
    [/ot]
    Genius*
    MobileThree: in car - Zotac Atom/ION - linuxICE 2.0.2
    --worklog--
  6. #46
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    i don't see any bondo on walmart at all
    http://images.google.com/imgres?imgu...icial%26sa%3DN
    thats the stuff
    PC Components:
    My work log
  7. #47
    Jun 2006
    Upstate NY
    well, in case your not being sarcastic....bondo, bondo hair, bondo glass...all that stuff is hardened chemically, not by air. putting plastic wrap over it doesn't increase curing time at all. and it peels right off after the bondo cures. then you sand
    VIA Epia M10k, M2 ATX PSU, Pioneer DVD slot load slim Writer, Lilliput 619, WD 3.5" 80Gb HDD, BU-353 w/iGuidance v.3
    Dash Fabrication 100%
    Computer Setup 100%
  8. #48
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    I think the dash is saveable. I'd just fill the holes, a nice wetsanding, primer, paint and your done.
    One thing you might want to try and experiment with is raycrete
    I love the stuff. It's non-toxic, sticks to about anything and has a nice working time. It thickens up instead of just turning hard all of a sudden. It's very easy to sand and shape the first 10 hours or so. At first, like soap, later like wood. I made my "mouse shifter" out of it, which basically had to be whiittled and sanded to get the right shape.
    Also used it to mount my lcd in my double din and my Sirius Radio in the clockpod.
    Only ***** is painting it. I found a good primer for it (Transtar 2in1 flexible primer).
    It's non-toxic to boot and cleans up with lemon juice. I just don't have the knack for glass (not enough experience) and I really hate bondo. Always have such a hard time getting rid of the little pits that come up while sanding. It can also be colored with concrete colorant.
    Another problem is I live in an apartment, so glassing/bondo is a PITA.
    (This was halfway through, I put more in there)
  9. #49
    _
    Mar 2004
    Little Elm, Texas
    my concern with just filling the holes in the dash is the amount of work, the amount of sanding and the amount of holes.
    No doubt, you will get cracking on one of those many holes.
    Jan Bennett
  10. #50
    Apr 2005
    Boston, MA
    Quote Originally Posted by Red GTi VR6 View Post
    You mean were you fill it or radiating out of the holes like a stress crack?
    I think bondo wouldn't last too long, but like I said, I've had great luck with the raycrete stuff. And it's so damn easy to sand at first.
    As far as the wetsanding, etc, you're talking to someone who did his dash like 5 times trying to get it just perfect and probably #6 coming up soon
  1. F/S: Voltmeter Gauge with Pod
    By ricerZ in forum Classified Archive
    Last Post: 07-05-2006, 09:35 AM
  2. Replies: 22
    Last Post: 03-09-2005, 10:27 AM
  3. anyone put a lcd in a gauge pod?
    By crash893 in forum LCD/Display
    Last Post: 11-18-2004, 09:10 PM
  4. Mounting motherboard in WRX gauge pod housing..
    By Giuliano in forum General Hardware Discussion
    Last Post: 07-19-2004, 09:01 AM
  5. WRX owners. Clock or Boost Pod Gauge area. Center channel Speaker.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 04-02-2004, 04:37 PM
