Fiberglassing Gauge Pod in Bezel *pics*
I started fiberglassing a gauge bezel in place of my left-middle AC vent in my dash bezel.
-I drilled small holes all over the bezel.
-Now do I need to fiberglass the back of the bezel as well, for it to stick, or just let the resin go through the holes and maybe put some more resin on the back, for it to stick?
-Also, will I have to fiberglass the whole bezel with matte?
...Or can I just use matte on the gauge area and fiberglass over the fabric around the gauge and a little further out, and then just put resin over the rest of the bezel, since the only part that needs major stability is the gauge hole?
-What's the best method to fiberglass this bezel piece?
But now should I pour resin over the whole rest of the dash to fill in all the small holes?
Here are the pictures. You can see the holes all over the whole bezel. This is what I have fiberglassed so far with about 2 layers of fiberglass.
-Also, how should I get rid of that lip where the fiberglass ends? theres about a 1/5 inch high lip of glass/fabric above the origional plastic. How should I ease this lip back to the origional plastic? I'm just not quite sure what the next step would be.
http://i101.photobucket.com/albums/m73/jmilin5931/3.jpg
http://i101.photobucket.com/albums/m73/jmilin5931/2.jpg
http://i101.photobucket.com/albums/m73/jmilin5931/1.jpg
