anyone??? i have the same question
I need some help trying to fit the LCD into my dash. The screen is larger than the opening in the dash and i can do 2 things, either fabricate an entire new dash panel to fit the screen or slice off the bottom part of the screen housing. I dont yet have my screen but i do have a couple of extra front casings of the LCD. If i cut off the buttons then it fits just perfectly and i would prefer to use this approach.
It was relatively easy to slice off the bottom of the casing i have but i wanted to know how hard is it to do it with the actual screen. I have seen some pictures of the xenarc from the inside but its hard to see if the buttons are located on a separate PCB that can be removed or is the entire electronic assembly a single unit. Could someone guide me the info or pictures that detail how to cut up the screen of the Xenarc ?
I saw the sticky thread about relocating buttons but thats using a different screen.
thanks.
i had the same problem, the buttons are on the main pcb, not a seperate one like the littliputs so i had to make room for them.
Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
Toys:K8055 relay board, Elmscan OBDII
Type-R Mini
