Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: Ideas for making a hinged opening in the dash
  1. #11
    Jul 2001
    You could always get a small chain to hold the thing up when it's in the "down" position
  2. #12
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Hey after looking at the first pic again, a piano hinge might just work after all. As long as it's straight. Cut off the bottom ears, but keep the middle ones. They'll help keep every thing aligned when it's closed. Though if you do end up using a piano hinge, you won't have to worry about that either.
    Failure is not an option....
    It's installed by default on every version of Windows.
  3. #13
    Constant Bitrate ankur's Avatar
    Aug 2006
    New Delhi
    Hey Barry,
    Thanks for you idea, something like this you mean ? www.ceshepherd.com/hinge_plastic.html
    I would probably have to cut it to the right size or i could try and find these http://www.craftechind.com/hinges.htm .
  4. #14
    Aug 2006
    New Delhi
    Found something to hold up the flap when it comes down. Maybe something like this http://www.lanyardsupply.com/lanyard...e-reels-14.htm
    But the damn string is too long.
  5. #15
    Jul 2001
    Those break all the freakin time. I've gone through 4 of 'em in a year for my ID badge at work.
  6. #16
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    get a linear actuator
    then you can just press a button
    lol
  7. #17
    Aug 2006
    New Delhi
    Quote Originally Posted by FC3S View Post
    lol
    aah! i wish it was that simple . I did search for a few of those after your message but they seem to be pushing out straight rods, in my case i would have to angle it and i dont know if there would be enough room for the motor housing. I had thought of a rotary type device earlier that would release a string or chain but didnt have much luck finding one.
  8. #18
    Jul 2001
    All you'd have to do to get a linear actuator to work is give it a little "L" bracket to push/pull on and some way to break the static tension when the thing is in the "down" position.
  9. #19
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    yeah, what shadow said
    but linear actuators are big and chunky, lol
    too bad no one makes any with like 3v hobby motors, i'd buy a million of those
  10. #20
    Jul 2001
    MPJA sells small linear stepper motors.
  1. Help on custom dash for Caddy STS
    By Slaughterhouse in forum Fabrication
    Last Post: 12-14-2006, 07:47 PM
  2. Replies: 0
    Last Post: 02-22-2005, 08:00 PM
  3. 2003 Altima Dash Fabrication
    By in4no in forum Fabrication
    Last Post: 02-11-2005, 11:51 AM
  4. Mounting idea's for a Mazda RX-8???
    By glxyjones in forum LCD/Display
    Last Post: 06-08-2004, 01:29 PM
  5. Mounting ideas for slimline dvd player in dash
    By psyclobe in forum General Hardware Discussion
    Last Post: 02-11-2004, 11:52 AM
