Page 2 of 15 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 149
Thread: how to: make a factory bezel
  1. #11
    Oct 2004
    NY
    at this point the bezel is hard like plastic, I use a black finish that is designed for exterior automotive trim... it is durable, doesn't fade, & is not too shiny & not too flat... a nice matte black finish.....
    a few wet coats & now we really start to see where we stand.... one big mistake most guys make is there afraid to go backwards... if you spray the piece & see low spots, or high spots, it's perfectly ok to let it dry, & then sand it & shape it more... I had a few contours that didn't look right, & a few dips that were only visable with a wet coat of black paint.... just dry & sandthrough.... shape........ paint it again...... sand it again taking as much material off as necissary to get a perfect finish..... paint again.... at this point the paint is also acting as a filler, as well as a guide coat... if you have enough patience & are critical enough to be able to see & acknowledege the flaws, & keep shaping... evenually you'll get a perfect finish......
    once I have my perfect finish, it then to be even more perfect, should be wetsanded & polished.... I wetsanded it once with an agressive 600, shaping & removing minor flaws several more paint coats, again agressive 600 sanding & perfexting even further..... then, when the piece is just perfect, wetsand with 2000, then hand polish..... buff to a glass finish.... this paint isn't a high gloss paint, & when it is polished it loos exactly like ... well..... plastic.....
    Name:  ali bezel 023.jpg
    Name:  ali bezel 022.jpg
    Name:  ali bezel 025.jpg
    Name:  ali bezel 026.jpg
  2. #12
    Oct 2004
    NY
    first shot is right before paint, notice how much the primer is sanded off... depending on the paint, you may want to do a final primer & not break through it for paint, with the paint I'm using it's not a problem because there is excellent adhesion, & I know I'm going to be sanding more & spraying more, I will use the paint for my final fill too....
    Name:  ali bezel 040.jpg
    Name:  ali bezel 032.jpg
    Name:  ali bezel 043.jpg
    Name:  ali bezel 044.jpg
  3. #13
    Oct 2004
    NY
    I use infrared lighting to speed curing... only in the initial stages though, to not over shrink the final coats.... they'll do better not being forced...
    a lot of wetsanding... basically you don't stop until it's perfect...
    Name:  ali bezel 033.jpg
    Name:  ali bezel 036.jpg
    Name:  ali bezel 047.jpg
    Name:  ali bezel 055.jpg
  4. #14
    Oct 2004
    NY
    final wetsand is 2000 & then polish....
    Name:  ali bezel 070.jpg
    Attachment 34436
    Name:  ali bezel 072.jpg
    Name:  ali bezel 073.jpg
  5. #15
    Oct 2004
    NY
    assembly....
    Name:  ali bezel 083.jpg
    Name:  ali bezel 086.jpg
    Name:  ali bezel 087.jpg
    Name:  ali bezel 088.jpg
  6. #16
    Oct 2004
    NY
    Name:  ali bezel 094.jpg
    Name:  ali bezel 095.jpg
    Name:  ali bezel 106.jpg
    Name:  ali bezel 107.jpg
  7. #17
    Oct 2004
    NY
    final lcd mounting, as promised... I heated the heads of the screws I used to mount the lcd, so they would be positively positioned & the key slot from the screw helps to avoid these turning loose & to perfectly position these for epoxy...
    then a bit of liquid epoxy.... this is strong enough to support the lcd, the touchscreen, & even the tiny touchscreen controller...
    Name:  ali bezel 113.jpg
    Name:  ali bezel 116.jpg
    Name:  ali bezel 114.jpg
  8. #18
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    turbocad6,
    I have to say this is one of the best fabrication write ups I have seen. Combined with the pictures it makes it an excellent guide. This thread should become a sticky. It is just that good.
    The teaser pics look fantastic. I am sure that your mate will be extremely happy and very impressed with your work.
  9. #19
    FLAC djmickyg's Avatar
    Feb 2004
    Fantastic.. I've been tring to do something similar with mine.. but Ive gone about it a few different ways, and I havent liked how they have turned out..
    I may have to try this way.
    thanks
  10. #20
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Now can I post??
    Excellent write up. I would rep you but I can't.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  1. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  2. Ford Explorer Custom Lilliput Bezel LOOK
    By CDesigns in forum Classified Archive
    Last Post: 05-29-2006, 11:23 AM
  3. factory power button
    By baller40 in forum General MP3Car Discussion
    Last Post: 10-19-2005, 04:14 AM
  4. How to make a new bezel from a picture frame
    By Psychobiker in forum Fabrication
    Last Post: 08-25-2005, 08:38 AM
  5. BMW bezel
    By Jir1984 in forum Fabrication
    Last Post: 07-15-2005, 03:40 PM
