Page 4 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 149
Thread: how to: make a factory bezel
  1. #31
    Constant Bitrate anik321's Avatar
    Nov 2004
    turbocad,
    one hell of a write up man.
    did you mention what the second material (by 3m) is called?
    99' V6 Solara SE.
    '05 CBR600RR
    Baltimore MD.
    Shuttle XPC| 512MB | 120GB 3.5" Seagate
    Opus 150W PS | Rikaline 6010 GPS
    7" Lilliput 619 | Centrafuse | IGuidance 3
  2. #32
    Oct 2004
    NY
    I attach this by cleaning both side edges (left & right), then very thin double sided tape to hold everything in alignment, you can see the thin red tape backing sticking out from the top in one of the shots... this is so I can slide my insert into possition without the tape sticking to it, then pull the red backing out & attach in the correct spot... I then epoxy from the rear.. I haven't completed this last epoxy step yet, so I left the last post for those pictures... I might be able to finish this tommorow...
    the 2 materials used..
  3. #33
    Oct 2004
    Sydney, Australia
    10/10
    Looks amazing, so the 2 bezels are epoxy glued at the back? You should make a tab/screw system to make it removable.
    Continued Worklog... Upgrades in progress:
    *15.4" WXGA LED backlight touchscreen upgrade
    *Custom fiberglass dash bezel
  4. #34
    Oct 2004
    NY
    yeah, that makes a lot of sense, & is what I originally planned, but me & the owner discussed both options, & in the end it was decided that this wasn't necissary, as he has no plans to do any further modifications to this piece, & refinishing it if necissary as an assembly isn't a problem if the need arose...
    also, I am adding 2 more ccfl's to this screen & a touchscreen, & it'll be more stury & the whole assy will be more stiff if bonded,,,,
    the main reason to do them as seperate pieces was so that I wouldn'ty harm my factory bezel in the process, but once done, there aren't to many drawbacks to it all being one piece like vertually all other bezels would be anyway....
    honestly, if it was mine, it would be removable, but that's cause I'm always tinkering & changing things around, this is more designed for drop in & forget it...
  5. #35
    Oct 2004
    Sydney, Australia
    ic ic nice work! I only read about 80% of your posts but why did you go with polished black as apposed to the texture grey? Is it to hard to get it a perfect match? It still looks OEM with the black tho.
  6. #36
    Oct 2004
    NY
    it looks more oem being black than if I matched the grey really, it matches the instrament bezel... it looks the best really in black to me... the other alternative was to match the silver down low, but we decided on the black for the low key factory look...
  7. #37
    Variable Bitrate cherrybomb's Avatar
    Apr 2005
    Southern Califorina
    First of all, super write-up, it's answered a whole ton of questions I had about the fabrication I plan to do.
    One question though.
    The LCD I got is an 8.4 that didn't come in any plastic case, meaning no trim piece to use as the base for my fabrication like you did. Any suggestions on how to reproduce this piece, or should I just look to cannibalize some other 8.4 screen?
    Thanks!
    '99 Ford Explorer Eddie Bauer
    CarPC Progress ~= 97%. Everything is installed, and operational. Still need to tweak and tune, and do some "finish" fabrication.
    CarPC Project Web Site
    SpaceNavigatorDriver SourceForge Project
    Check out my blog.
  8. #38
    Oct 2004
    NY
    this lcd that I used is also just an open frame design, I used any old bezel just for the opening precut & perfect, but it doesn't make mounting the screen any easier....
    if I didn't have anything, then I'd have to create my opening... that can be a *****, but I've done it before... the best advice I could give to do something like this is it's easier to form your opening with 4 straight edges rather than trying to cut a perfect opening.. the last one I did, I used 4 stainless steel thin rulers, this adds some problems because instead of trying to get perfectly mitered edges to match up, your better off overlapping... then this is cool because the stainless steel edge is what you sand to, it is easier to start with something that has your opening though....
    in your case it should be easy enough, just order a spare lilliput housing for an 8.4... I think they have them in the store, & there cheap enough, & if your really lucky it may even help you with mounting too..., I have to order one too now that I think of this... , I'm doing an 8.4 in my car overhead...
  9. #39
    Newbie dynamok's Avatar
    Nov 2003
    Coon Rapids
    turbocad6, where do you get either of those two products dynatron and the 3M? I've searched online and found nothing.
    Thank you
  10. #40
    Oct 2004
    NY
    I know someone sells the dynatron on ebay, any bodyshop supply house should have it too... & the 3m stuff....
  1. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  2. Ford Explorer Custom Lilliput Bezel LOOK
    By CDesigns in forum Classified Archive
    Last Post: 05-29-2006, 11:23 AM
  3. factory power button
    By baller40 in forum General MP3Car Discussion
    Last Post: 10-19-2005, 04:14 AM
  4. How to make a new bezel from a picture frame
    By Psychobiker in forum Fabrication
    Last Post: 08-25-2005, 08:38 AM
  5. BMW bezel
    By Jir1984 in forum Fabrication
    Last Post: 07-15-2005, 03:40 PM
