Page 9 of 16 FirstFirst 12345678910111213141516 LastLast
Results 81 to 90 of 153
Thread: how to: make a factory bezel
  1. #81
    Oct 2004
    NY
    that could definatley work, in your case a complete fiberglass new bezel can be a good idea, theres not much of the existing stuff that's usable for you anyway....
  2. #82
    Mar 2005
    NYC
    turbo- You've seen my bezel, but the one I used with your method was for a 97' Talon TSI with an 8inch t/s monitor which I managed to sqeeze in pretty good. It came out like this, but I can't find the images of it painted. Cig. lighter was relocated to the side of that panel where the monitor was installed.
    And a BMW 530 with a 7in Xenarc700TS. I used cardboard to support the back, then used the Urethane Bumper kit to fill in the rest. I don't have pics of the processes...but here is the result!
    NOTE: All that is there is the monitor, two pieces of thick cardboard that was hotglued to the monitor and then filled with the same stuff. two layers of cardboard was used on the botton half and then glued the wood trim pieces into place to match the rest of the dash!
  3. #83
    Jul 2007
    primer?
    Turbocad6
    Thanks by the way you rule men...I busy farbing my bezel for a land rover discovery...and I got a dumb question for you..by primer do you mean the 3m stuff or primer paint..let me know thanks...
  4. #84
    Feb 2007
    I'm looking at doing a similar build, and was wondering exactly how you apply the dynatron around the initial gaps (ie - the large arced gap between the screen bezel and the factory faceplate on the sides)? Do you apply it directly onto the tinfoil and then peel the tinfoil off the back once it has dried (15mins)?
    Thanks! :-)
  5. #85
    Oct 2004
    NY
    yes, the tin foil is like a mold of sort, it will contain the stuf till it hardens, the tin foil doesn't release as nicely as I would have liked, but on the back side it wasn't a problem
    I missed the post above yours, but primer I mean primer, I used a bumper primer for flexability & buildup, but a regular primer should do fine too.
  6. #86
    Jul 2007
    hey turbo
    im going to use your technique to build my bez.... i went to get some dynatron and some of the m3 that you used, and the shop i went to said they didn't sell dynatron they said fasco epoxo 88-t10 is the same and it will work.... what do you think
  7. #87
    Nov 2007
    This is my custom Double Din I Fabed up don't have the head unit yet Kenwood DDX7019 ordering this week will post more pics later. Its a 300m No Carputerbut thanks for the info Turbocad6
    I forgot to take some pics when i started
    [/img]
  8. #88
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Awesome writeup (and work, of course!) turbocad! Thanks!
  9. #89
    Newbie Tacfire11's Avatar
    Nov 2007
    WOW, that's beautiful work
  10. #90
    Nov 2007
  1. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  2. Ford Explorer Custom Lilliput Bezel LOOK
    By CDesigns in forum Classified Archive
    Last Post: 05-29-2006, 11:23 AM
  3. factory power button
    By baller40 in forum General MP3Car Discussion
    Last Post: 10-19-2005, 04:14 AM
  4. How to make a new bezel from a picture frame
    By Psychobiker in forum Fabrication
    Last Post: 08-25-2005, 08:38 AM
  5. BMW bezel
    By Jir1984 in forum Fabrication
    Last Post: 07-15-2005, 03:40 PM
