Results 1 to 10 of 12
Thread: Screen mount suggestions (moveable)?
    Aug 2006
    I've got the case for my car pc made now and have the motherboard mounted in it (the holes at the back were a nightmare with no back plate!!), but my next big hurdle is going to be mounting the screen and I was hoping someone could help with ideas.
    I want to have a slimline slotload dvd drive inside the main unit, (already have one) but that means the screen will have to be able to move in one direction or another to give access to the drive.
    It'd be very interested to know if anyone else has done this and if so how they went about it and what sort of fabrication was involved/or any other bits they bought to help with this.
    Pics attached so you can see what I have so far in case that will help.
    Thanks in advance for any useful suggestions. The only thing I have surmised so far is that the screen will probably need to slide/fold downwards as the motherboard is at the bottom of the case & it'd make sense to have the drive at the top therefore.
    Cheers!
    Jim
    The other thing I was wondering about was the VGA connection on the back of the board - it'd be nice to have it all inside the case but how easy is it to do this? I'm a bit scared of breaking the mobo by trying to remove the vga connector & soldering the wires directly in.....
    What I think would be a good compromise would be if there is some kind of small 90 degree adaptor for the vga socket so that the socket would effectively face upwards from the back rather than straight out, at least then the plug can go down the rear panel instead of sticking right out. Hope that makes sense!
    Maximum Bitrate Meatballman's Avatar
    Jul 1999
    Hartsville, SC
    Markertek makes a right-angle VGA adapter, either up or down.
    Looks like they're available here even cheaper.
    Feb 2006
    Vancouver, BC
    Hey Cret,
    this is what I'm planning on doing for my install except instead of hiding the slot drive, I'll be hiding my HU behind the screen. In the pictures it isn't shown the fact that the top of the screen will need to ride is a track of some sort to maintain the correct swivel movement.
    Aug 2006
    Thanks for the replies fellas. That right angle adaptor looks ideal - will have to see if I can get one in the UK or on Ebay or something.
    The sliding system on yours looks cool but a bit more elaborate than I was planning I must admit. I was literally thinking of a pivot at the base of the screen with something to make it move smoothly (was thinking something like two shock absorbers from one of my model cars without the springs), and some means of 'clicking' it into place at the top.
    I can't think of an easy way of having it pivot at the bottom though.
    I've picked up various bits of metal rods & tubes etc but can't see a practical means of setting it up.
    Aug 2006
    I did actually find the perfect enclosure on here last night anyway so I may have a crack at doing something vaguely similar, albeit probably a lot less professional than this. If only these were available to buy.
    Double din case with swivel face
    Jul 1999
    Hartsville, SC
    Quote Originally Posted by Cret View Post
    If you need me to pick one up and mail it to you, just let me know. We can settle up with paypal or something.
    Aug 2006
    Many thanks for the offer but I just managed to find a place in the UK selling them so I've literally just ordered one.
    Appreciate the offer though - cheers!
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Cret - I was going to suggest Double din case with swivel face but it seems you found it.
    And I'll put my thinking cap on too - in the mean time ... have you thought that you may get a lot of heat in the case if you stereo is in too ? May need extra fans etc.
    What I would do ( well did ) was mount the head else where - in my case the glove box box there is no real need for access to it. You can repleace it with an amp all together but I can't remeber if the M1 has the amp aux on out put.
    If its for the DVD drive I would argue that in all my time I've never had the need to use one other than install and even then one of these may be better. Just have a very large hard drive and update every so offten via WIFI / LAN.
    That all make the install a bit easier.
    Lastly - one thing I am looking at my self ( because of what we discussed ) is using my GPS but not for routing as maps there are not that great. I'm thinking about using a cache of google or MSN which should not be that big.... it will look quite good as well.... may be some thing to add to your list ?
    Terran
    Aug 2006
    Thanks for the comments fella - the head unit, well it would be nice to keep it but I wasn't really planning on it as there isn't the space unless it went in the glove box and I just hink it'd be a bit pants there to be honest.
    I've got a Dlink USB tuner and already have amps in the car. Been given an Audigy sound card to test too when I can get a suitable riser to fit it in the case.
    I suppose I could do away with the DVD drive and it would make life so much easier but I thought it would be a useful addition and I don't want to admit defeat, although I may end up doing so in the end.
    You've got me thinking now if I should just do without and take the easy life....
    If I could find some very small bearing drawer runners that would be a start....
    I do plan on adding a USB GPS device at some point - no rush as I certainly don't need it over here! Useful for trips across though.
    Was going to have a USB extension cable coming to a few ports on the dash too so I can plug in wifi dongle etc.
    Jan 2003
    I found I did not need the extension... just ran it to a bus powered up and was OK.
    That been said I had to play about with the devices to balance the power.
    What I'm planning on is a camera screen via my web site to match my skin ... in fact I have a version running but I can't publish it due to whats on... if you intrested let me know by PM...
    Any way I digress - the idea would be to acces say the mountian camera feeds as your going up or even before to let you plan your trip just by pressing the button. This then could be dragged accross GPRS to your screen...
    GPS units you can pick up for next to nothing now ... may be you can find a use for it
    Terran
  1. FAQ: Touchscreens explained
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 07-21-2008, 10:10 AM
  2. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 03:19 PM
  3. Dash mount screen in GM Chevy Tahoe
    By slushieken in forum LCD/Display
    Last Post: 06-19-2006, 03:31 PM
  4. WTB: The Mount that comes with the Xenarc 700 series Screen
    By tavenger5 in forum Classified Archive
    Last Post: 06-05-2005, 12:59 PM
  5. Just bought a "project" dash.. pda mount suggestions?
    By CA 3000GT in forum Fabrication
    Last Post: 06-01-2005, 12:28 AM
