Results 1 to 10 of 13
Thread: Would this be easy to color match?
    Jun 2006
    I have a 2006 Ford Fusion with Piano Black interior. Here's a pic below...how easy would this be to fabricate and color match to look factory?
    Mar 2004
    Maryland/NOVA
    Probably not too hard with the right primer, paints, and sealant. It would require a lot of sanding to make it smooth.
    I'd also look into glossy black vinyl.
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
    Sep 2005
    Easy take it to a body shop or even home depot and have them scan the color and mix it up for you. Some body shops can even make a spray can of the paint for you.
    -Mike
    Jul 2001
    Umm, if you use interior wall paint on your car, you deserve to be shot.
    You can get a little can that you pour automotive grade paint into and there's a little butane propellant can you put on the bottom. It's like a rattle can but it's WAY better stuff.
    Jul 2001
    that black color looks to be your car's body color so an auto body supply shop is your only bet
    Constant Bitrate blacklancer's Avatar
    Nov 2005
    Los Angeles, Ca
    OOOOORRRRRRR
    go to www.paintscratch.com and order the factory color in a spray can and save yourself A LOT of time and $$$
    Jul 2001
    Have you tried the spray cans yourself? What kind of results did you get, id like to see pics if you dont mind this looks kinda interesting
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    no matter what your paint in the car you must prime it, is the part is plexible, i would go with latex paint on the primer
    Yev
    R. T. F. M
    Nov 2005
    Los Angeles, Ca
    i've never used the cans from paintscratch, but i've used spray cans many times.
    the whole thing with painting interiors, is like yevmeister said, you have to use a primer. then use really thin, light coats. i would use a clear coat when you're done, especially to make it nice and shiny like the factory piece.
    take your time though, and it'll turn out just fine.
    Jul 2001
    Even if it's not plexible?
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. easy switching between "access point" and "ad hoc" mode?
    By urosbe in forum Wireless Communications
    Last Post: 03-08-2006, 12:37 PM
  3. easy question
    By GolfChick22 in forum Road Runner
    Last Post: 12-31-2005, 02:16 PM
  4. Car radio "hack" is EASY!!!!
    By THEMP3KID in forum General Hardware Discussion
    Last Post: 07-19-2002, 10:48 PM
