Results 1 to 8 of 8
Thread: Method of Bonding fiberglass with ABS plastics
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    For Search Nazis i did the search, and found few but not deep enough
    i was wondering if i could get some epoxy apply is as a layer on ABS plastic, later when i am finished with glass, would resin bond to it
    Yev
    R. T. F. M
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    Duramix.
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    Out of curiosity, have you tried using construction adhesive like PL? Seems to me that something tough enough to bridge a 3/8" gap and hold things to houses in the elements might do okay in a car... just a thought, no promises.
    Nov 2005
    Chicago
    Quote Originally Posted by Naamanf View Post
    Duramix.
    got it so just finish the panel, that i would like to add on, some duramix, sand, and glazing putty, vynil and i should be set?
    Would regular epoxy work as well the reads "bonds plastic, fiberglass etc. " on the label
    Yev
    R. T. F. M
    Jan 2006
    Believe it or not, Ive been in the process of using PVC Cement...after it cures, it acts like a plactic, flexable but won't un-bond. Also, its fairly sandable too. Hope it helps
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    SEM Plastic adhesion promoter spray
    http://store.detailandstripes.com/sem-39863.html
    2nd bottle from the left
    Jul 2001
    what are you trying to do? Once I know that much I can try and help some
    Nov 2005
    Chicago
    i will get some pics tomorrow,
    Yev
    R. T. F. M
  1. My try at ABS sludging a xenarc
    By evandude in forum Fabrication
    Last Post: 08-09-2006, 01:20 AM
  2. Fiberglass ABS
    By zerocover in forum Fabrication
    Last Post: 06-15-2006, 01:57 PM
  3. Salvaging my ABS sludge install with fiberglass?
    Last Post: 02-11-2006, 06:22 PM
  4. Fiberglass or ABS?
    By Abraxsis in forum Fabrication
    Last Post: 09-21-2005, 11:08 AM
  5. 100% ABS LCD install with texture
    By Snootch in forum Fabrication
    Last Post: 07-11-2005, 02:16 PM
