Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 58
Thread: Fiberglassed Gauge Pod in Bezel: FIXED *pics*
  1. #31
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    out of cusiousity, what is the best budget set up, the HLVP gun, and what trype of compressor to get, there are so many specs out there.
    I was thinking of getting one of wagner main sets, and getting a separate gun, but i am just clueless.
    Yev
    R. T. F. M
  2. #32
    Jul 2001
    If you're going to be doing a lot of painting you should invest in an air dryer. It goes inline with the supply valve and takes all of the moisture out of the air so it doesn't get shot out of the other side. Look for a compressor that can do 90+ CFM . Most paint guns will have different CFM requirements at different air pressures. Different paints require different pressures. The longer you spray the more air you're going to need. If you never go above 90CFM and that's what your compressor is rated for and it's constant duty then you'll never have any problems.
  3. #33
    Nov 2005
    Chicago
    Quote Originally Posted by Shadow View Post
    thank for info, i think got it now, i have been doing scale modeling airbrushing, so i have a small airbrush compressor, but i had no idea of what are requrement for biggle HLVP guns, it's cleared up now
    Yev
    R. T. F. M
  4. #34
    Jul 2001
    heres just a quick link I googled for the sem stuff. Note - I have never done business with these people. You should be able to pick this stuff up locally at any auto body supply shop for a good price.
    http://www.autobodydepot.net/scripts...m=sealcoat.bbx
  5. #35
    Nov 2005
    Chicago
    Quote Originally Posted by Ces///M3 View Post
    wow that's the awesome stuff, i am finishing upholstering my doors with vynil, now i can change my vynil interior, anythime i like
    Yev
    R. T. F. M
  6. #36
    Jul 2001
    That stuff works well, they carry it in spraycan and mixed form. Just make sure to prep the plastic well. No sanding is neccessary, sand free prep workks flawlessly. Just get the pieces completely spotless, then remove oils etc with alcohol. Let dry thoroughly. Give a coat of sem plastic preplet dry .Coat of sand free. Let dry. Then sem paint. Beautiful scratch resistant outcome
  7. #37
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by jmilin5931 View Post
    no gauges. A dynotune nitrous switch panel.
    the dash came out great! It seems a shame to put that nos panel in there. have you thought about using the gauge pod for a n2o pressure gauge and maybe putting those toggles/led's in the open area around it?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  8. #38
    Jul 2001
    Scott, do you like having 900+ psi hoses routed around inside your car? I don't. There's a reason that you're not supposed to have a fuel pressure gauge or nitrous pressure gauge in the cabin, if a line busts, you're SOL.
  9. #39
    Dec 2004
    Los Angeles Ca
    certainly not.. that is why they have electrical gauges for this type of application.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  10. #40
    Jul 2001
    The electrical gauges suck for liquid pressure gauges.
  1. Fiberglassing Gauge Pod in Bezel *pics*
    By jmilin5931 in forum Fabrication
    Last Post: 10-04-2006, 09:04 AM
  2. F/S: Voltmeter Gauge with Pod
    By ricerZ in forum Classified Archive
    Last Post: 07-05-2006, 10:35 AM
  3. anyone put a lcd in a gauge pod?
    By crash893 in forum LCD/Display
    Last Post: 11-18-2004, 10:10 PM
  4. Mounting motherboard in WRX gauge pod housing..
    By Giuliano in forum General Hardware Discussion
    Last Post: 07-19-2004, 10:01 AM
  5. WRX owners. Clock or Boost Pod Gauge area. Center channel Speaker.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 04-02-2004, 05:37 PM
